Question about Traxis DBS-1500
Traxis DBS-1500 Remote code
Where do I find the code to program my Traxis DBS-1500 to work with my TV remote
What i need is the program to load the channels
Posted on Oct 11, 2008
There are no codes for that particular remote. Galaxy-Marketing.com should have some in stock in about a week or so. This is the only stock that will be available in the USA so you may want to call them up and plae a few on back order.
Posted on Oct 29, 2008
Program a JVC remote to operate a SONY CD/DVD Player (DVP-NC85H)
Becuase this model IS a DVD player, the remote controller will not allow another of the same type. This remote can be programmed to control a TV, Cable Box, DBS tuner, and VCR. It will not control VHS or another DVD player
Sep 18, 2014 | JVC Remote Control RM-STHD5J p/n:RMSTHD5J
How to install a remote control to JVC TV?
  • Dear Sir:
    Please do the follow steps:
    Move the mode selector on the remote to "TV" and press and hold the television power button. Press "Enter."
  • 2
    Enter in the manufacturer's code for your television or other electronic device. The code is typically 2 digits long. The JVC manufacturer's code is "01." Other codes include "10" for Hitachi, "02" for Magnavox, "07" for Sony, "04" for Panasonic and "08" for Toshiba. Additional codes can be found in the user's manual for the JVC universal remote. Release the television power button.
  • 3
    Program a direct broadcast satellite (DBS) tuner by setting the mode to "VCR/DBS" and press "DBS." Press and hold the VCR/DBS power button and press "Enter". Press the buttons for the manufacturer's code, which are typically 2 digits. RCA is "19," Pioneer is "13," EchoStar is "21," GI Jerrold is "01" and Sony is "20." Additional codes can be found in the universal remote user's manual. Release the VCR/DBS power button.
  • 4
    Press the "Audio" power button to use features other than the television, such as a DVD player or stereo, and select the desired source. The options are DVD, FM/AM, VCR or DBS.
  • 5
    Set up the speaker settings by choosing "DVD" as the source. Hold the remote where you listen to the sound from the home entertainment unit. Press and hold "Smart Setup." Press "Enter" and move the cursor up and down on the television screen using the up and down arrows to select the distance between the front speakers and where you are positioned. Press "Start" and then "Enter.
    SINCERELY.GOD BLESS YOU
    ernesto cuadra
    managua, nicaraguaa c.a.
  • Feb 15, 2012 | One For All URC-3021 Remote Control
    Got a dbs traxis from sister and need to reset password
    • To reset the password you need to first restore this unit to factory defaults. Then you can use the default code "0000" or have the old code and change it to a different code entering the old code first.
    • To restore to factory defaults follow these steps -
    1. Use the ^ v arrows to select "erase all channels" or "factory default."
    2. Now press the OK button.
    3. There will be a warning display then just press "OK" again.
    4. The receiver is now restored to factory defaults.
    Regards, Tony
    Jun 14, 2011 | Traxis DBS-1500
    I need to know how to program a RCA universal remote RCU404N
    Hello
    Programming method for your remote control follows:-
    In order for the 4 component universal remote to control your DVD player or auxiliary component, you must program it with the code that matches your component. The DVD•AUX key can be programmed to operate a DVD player or a second TV, VCR, DBS or cable box. These instructions explain the preferred method of programming the remote-the Direct Entry method.
    1. Manually turn on the component you wish to assign to the DVD•AUX key (TV, VCR, DVD, DBS System or cable box).
    2. Locate the enclosed DVD code list, or the
    corresponding code list for the auxiliary component (TV, VCR, DBS, or cable box).
    Note: If your brand isn't listed, use one of the Code Search methods to program this remote control (See Code Search on page 9).
    3. Press and hold the CODE SEARCH key until the INDICATOR LIGHT illuminates, then release the CODE SEARCH key.
    4. Press and release the DVD•AUX key. The INDICATOR LIGHT will blink.
    5. To program for DVD, press the VCR key. For an auxiliary component, press the corresponding component key (TV, VCR, DBS•CABLE). The INDICATOR LIGHT will blink again, then remain lit.
    6. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off.
    Note: If you enter an invalid code, the LED will flash rapidly for 2 seconds. Start over at step 3.
    7. Aim the remote at your component and press the ON•OFF key. If your component turns off, you have found the correct code.
    8. Enter the code in the box provided on this page for future reference.
    9. If your component doesn't turn off, repeat steps 3-7 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote (See Code Search on page 9).
    Mar 18, 2011 | RCA Televison & Video
    I have an rca rcu404n remote i need the code for trutech tv.
    RCA does not list a code for the Trutech TV. Trutech says that their TV is not compatible with universal remotes.
    Some people have said that they had luck with Daewoo codes. You could try 016, 190, 005, 171, 004, 006, 017, 127, 196, 202, 222.
    If that does not work, you might also try the code search method.
    1. Turn on the device you wish to program.
    2. Press and hold CODE SEARCH until the indicator light lights, then release.
    3. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit.
    4. Press and release off-on until your device turns off. You may have to press off-on up to 200 times.
    5. When your device turns off, press the ENTER button and the indicator light will go off.
    Nov 11, 2010 | RCA RCU404 Remote Control
    I have an RCA tv and I can't find a code that will work with my dish 5.3 remote. in addition I even tried to do the ir programing and can't get it to work. Can this remote be used with RCA?
    Here are some steps and codes for your tv and DISH Network. I hope this helps.
    1. Hold down the clear TV button until all lights light up at the top of the remote
    2. Punch in a 3 digit code (provided below)
    3. Press the # (POUND) button
    4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
    641
    503
    627
    645
    Becki Barned
    DISH Network Customer Service
    Sep 14, 2010 | RCA SONY Dish Network and DirecTV...
    Password for traxis dcs-2500
    i forgot the parental
    password
    Nov 06, 2008 | Traxis DBS-2500 DTV Receiver
    Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
    It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
    A
    Turn on TV
    Turn on the TV using the Power button on the TV or its Remote.
    B
    Set TV brand code
    A
    Press and hold TV.
    B
    Press MBR SET.
    C
    Press the Number keys to enter your TV.s brand code.
    D
    Press OK, and release TV. The TV should turn off.
    C
    Operate TV
    While holding down TV, press one of the following buttons:
    POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
    and the Number keys.
    For some brands, you must press ENTER after having pressed the
    Number keys to enter a channel number.
    TV BRAND CODE TV BRAND CODE
    JVC 01, 03
    SONY 07
    HITACHI 10
    SAMSUNG 12
    MAGNAVOX 02
    SANYO 13
    MITSUBISHI 03
    SEARS 13
    PANASONIC 04, 11
    TOSHIBA 08
    RCA 05
    ZENITH 09
    SHARP 06
    Cable Box or DBS Receiver Brand Setting
    A
    Turn on cable box or DBS receiver
    Turn on the cable box or DBS receiver using the Power button on
    the unit or its Remote.
    B
    Enter brand code
    A
    Press and hold CABLE/DBS.
    B
    Press MBR SET.
    C
    Press the Number keys to enter your cable box.s (or DBS
    receiver.s) brand code.
    D
    Press OK, and release CABLE/DBS.
    C
    Operate cable box or DBS receiver
    While holding down CABLE/DBS, press one of the following
    buttons: POWER 1, TV CH+/., and the Number keys.
    To change the cable box.s (or DBS receiver.s) channels, press TV
    CH+/–
    or the Number keys. (The CH+/–
    button can be used to
    change the VCR.s channels only.)
    CABLE BOX BRAND CODE
    ARCHER 01, 05, 17
    CABLETENNA 01, 17
    CABLEVIEW 15, 16, 17, 21, 25
    CITIZEN 15, 16, 17, 21, 25
    CURTIS 02
    DIAMOND 01, 17
    GC BRAND 15, 16, 17, 21, 25
    GEMINI 15
    GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
    HAMLIN 10, 18, 23
    JASCO 15
    JERROLD 01, 04, 06, 11, 12, 15, 28
    NOVAVISION 02
    OAK 07
    PANASONIC 13, 14
    PULSER 15, 16, 17, 21, 25
    RCA 13, 14
    REGAL 10, 18, 23
    REMBRANDT 01, 16, 17
    SAMSUNG 05, 16, 24
    SCIENTIFIC ATLANTA 02
    SIGMA 07
    SL MARX 05, 16, 17, 24, 25
    SPRUCER 13, 14
    STARGATE 05, 15, 16, 17, 21, 24, 25
    TELEVIEW 05, 16, 24
    TOCOM 01, 04, 16
    UNIKA 01, 17
    UNIVERSAL 16, 17, 25
    VIDEOWAY 03, 09, 22
    ZENITH 03, 09, 22
    DBS RECEIVER BRAND CODE
    JVC (DISH Network) 51
    ECHOSTAR (DISH Network) 51
    SONY (DSS) 41
    RCA (DSS) 40
    Changing Remote Control Code
    This Remote is capable of transmitting two control codes; one set
    to respond to A code control signals and another set to respond to
    B code control signals. This Remote control is preset to send A
    code signals because your VCR is initially set to respond to A code
    signals. You can easily modify your VCR and the Remote to
    respond to B code signals. When using two JVC VCRs, set two
    VCRs and their Remotes to different codes, so that you can
    operate these VCRs separately.
    A
    Set remote control code for Remote
    A
    Press and hold A/B.
    B
    Press the Number key .2..
    C
    Press OK, and release A/B.
    The Remote now can transmit B code control signals.
    B
    Check remote control code for VCR
    Press and hold 4
    on the VCR for more than 5 seconds while the
    VCR is turned off. The code currently set appears on the display
    panel.
    C
    Change code for VCR
    Press any key on the Remote. The VCR now responds to B code
    control signals.
    To set the Remote and the VCR back to A code control signals,
    repeat the same procedure as shown above except pressing the
    Number key .1”
    in step B
    of 1
    1111.
    To control two VCRs with the same Remote
    You can control two JVC VCRs by switching the remote control
    code for the Remote between A and B (.
    step A
    AAAA), keeping two
    VCRs to different control codes.
    To change only the remote control code for the Remote, DO
    NOT perform steps B
    BBBBand C
    CCCC.
    Mar 19, 2008 | JVC RM-C18G-1H Remote Control
    Need code for remote control
    Code Search Method: Turn on the device you wish to program. Press and hold CODE SEARCH until the indicator light lights, then release. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit. Press and release off-on until your device turns off. You may have to press off-on up to 200 times. When your device turns off, press the ENTER button and the indicator light will go off. Code Entry Method: Manually turn on the device you want to program. Find the code for your device in the code list. Press and hold the CODE SEARCH button until the indicator light lights, then release. Press and release the device you want to program, the indicator light will blink then remain lit. Enter your code using the number buttons.After your code is entered the indicator light will turn off. Aim the remote at your device and press the off-on button. The device should turn off. APEX CODES: 006,014,033,035,036,039,041,152,247,172, 173
    Sep 15, 2007 | Televison & Video
    Traxis DBS-1500 Logo
    373 people viewed this question
    Top Traxis Televison & Video Experts
    Electro Med Services...
    Are you a Traxis Televison and Video Expert? Answer questions, earn points and help others
