Question about Car Audio & Video
Wiring installation on Majestic amplifier total 60watts 2x30 model# ma-60
Need help with installing this amp
  • 56 Answers
To install the amp you need a amp wiring kit they range from $15 and up depends on how many watts u have.Once you have the wiring kit start with the ground wire it needs to be no longer then 24 inches long the shorter the better find a good ground in the trunk or where ever you want to install the amp make sure its metal to metal no plastic paint or any other debrie is in the way of the metal.If you can't find a paint free surface all you will need to do to fix this is sand off some of the paint and then ground the amp.The ground wire needs to be connected to the amp before any other wire once you have the ground connected then connect the battary wire make sure you have the right size inline fuse on the battary wire that also depends on the watts of the amp.once you have those 2 wires connected then u will need to pull the stereo out of the dash and hook up the remote wire to the power antanna wire if you have a factory car stereo and don't have a power antanna you can try one of these solutions 1st one Run the remote wire from the battary wire on the amp and use a toggle switch between the remote and battary wire or you can run the remote wire from the amp to the fuse box of the car and hook it up to a fuse that only works when the key is turned on.Once you have all this hooked up its time to hook up the subs/speakers on the amp it should indicate if its bridgable it will show lines from one positive and one negative and at the top of the lines it will say bridge but if not the just connect the speakers positive to positve and negative to negative.If it is a bridgeable amp i would only recommend hooking it up bridged if you are hook up subs if you are using 6x9's on the amp you don't need to bridge the amp.If u have any more ?'s just ask i can help with this i've done this alot.
Posted on Oct 11, 2008
  • Zachary Drewery
    Zachary Drewery Oct 11, 2008
    oh by the way make sure when u install the remote wire to hook up the rca audio cables to the back of the stereo.Same thing though if u have a factory car stereo then you will need a Speaker Level Converter this allows you to hook up rca audio cables to a factory stereo it cost about $20
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
Wire from car battery to amp melts fuse holder
total the fuses on the amp eg.3 -20amp fuses = 60 amps and get a fuse holder that can handle that amount of amps the amplifier draws with matching fuse and change the one that was melted ,also very important is to have a clean grounded wire to chasis from amplifier.
Mar 10, 2013 | Maystar QXV10 Car Subwoofer
I need a pictorial diagram of a 100 watt audio amp
GOOGLE YOUR MODEL NUMBER THEN TYPE IN WIRE DIAGRAM SHOULDNT B TO HARD AT ALL GOOD LUCK W UR SEARCH
Feb 05, 2010 | Majestic MA3100R Car Audio Amplifier
How do you bridge the amplifier
well you need to make sure you have a atleast a two channel amp first. If you do, connect both positive speaker wires to one channel and both negatives to the other channel
Oct 15, 2009 | Majestic MA7600A Car Audio Amplifier
I have 800w majestic amp it won't turn on what parts do i need to fix it amp is 2oyrs old
have you checked the fuses on the amp if so you can try to check for power of the amp straight from the battery by connecting the remote wire and power or battery wires together putting them on the positive terminal on your battery and the ground or earth wire on the negative terminal on your battery if there is no faults it should light up
Jul 26, 2009 | Majestic MA6300R Car Audio Amplifier
Amp is powering on at all
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Aug 16, 2008 | MA Audio HK4000D Car Audio Amplifier
Transistors
Are the transistors missing?
You're unlikely to find a schematic for it. Since the amp is likely a clone, you may be able to use a schematic from another manufacturer to troubleshoot it. If you can send me a clear photo of the power supply components around the TL494, I may be able to help.
babin_perry@yahoo.com
Jul 31, 2008 | Majestic MA4200R Car Audio Amplifier
Fuse
try a 60 amp fuses if it doesnt blow when you crank it up it safer lest chance to frying something 100 amp is lots of juice
Jan 17, 2008 | Alpine MRP-M650 Car Audio Amplifier
Car Audio & Video Logo
398 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
