Question about Konica Minolta DiMAGE 5 Digital Camera
How long does it take to load an image in Playback?
    Master:
  • 425 Answers
It will take approximately 0.2 seconds to load a frame in the playback mode.
Posted on Sep 15, 2005
Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Dec 18, 2007 | Fuji FinePix S5700 Digital Camera
Cannot view image. get message "cannot playback image"
There are four possible reasons that this could happen, so you need to do some tests to diagnose which one it is.
1. It could be that you shot some photos in "RAW" and the photo viewer is not capable of decoding raw images. (You should have a digtal developing software such as LightRoom for this, or installing the right Canon software might include the decoder that allows other programs to access it.) To test for this, check the full name of the files; if you can read all the .JPG files, but none of the .CR2 files, this is your problem.
2. It could be that your card is corrupting the data. To check for this, try a different card. (Any card will work for photos.)
3. Failing the other two, either the camera is producing corrupted data, or your image viewer is not capable of reading them. To discern which, try a different image viewer. If you don't want to install one, upload it to a photo sharing site, or just view it in your browser (you can drag and drop).
Jul 28, 2012 | Canon EOS 550D Rebel T2i Digital Camera
As stated. What I need to know is more in depth as to internal as well external hdd supported. Is main app(My Movies)_ to be used only from os main hd with win 7 home premium. if I go with My Movies, I...
I have no idea what the question is here, if you are following up to an oriignal post then always use the same thread, never open a new one for the same problem, to go to the original problem click My Profile at the top of theis screen, in the next window schroll to the bottom of the page, there u will find a list of your open problems, find the original thread then click it, copy and paste this info into the window and send it to the expert that helped you in the original thread.
Feb 18, 2010 | Computers & Internet
Problems trying to play back images on my CF card
Sometimes if you take the card from the camera to the computer and the computer rotates the file from landscape to portrait it will no longer playback on the camera.
Aug 05, 2009 | Canon EOS 40D Digital Camera
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D40X - playback
Try formatting the card then using it again. Does this work?
Jan 10, 2008 | Nikon D40x Digital Camera
Optical / Digital Zoom
Press the "T" for telephoto and get closer to the subject. Optical telephoto zoom is like using a telescope to get closer to the subject before taking the picture. With optical Telephoto zoom you can maintain the full resolution and quality. After you have used all of the optical Telephoto range, the camera will continue to enhance the image with Digital Zoom. This enhances the image inside the camera by reducing the resolution and expanding fewer pixels to fill the same image space. Use the "W" Wide-angle button to back-up away from the subject or get a bigger area into your picture. You can even ZOOM IN on a picture in the playback mode for a better look at the details. Turn the Mode Dial to Playback, then press the "T". Use the Enter button to move around the display area. Press the middle of the ENTER KEY to see your images in thumbnail view and / or scroll through several images at one time to find a specific / special image quickly.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Playback modes
There are playback modes such as single-frame, Index (you can select the number of frames to display on the monitor from 4, 9 or 16 frames), Close-up (2x through 10x magnification), Slideshow (display the stored images one after another in succession) or playback images by rotating.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Konica Minolta DiMAGE 5 Digital Camera Logo
85 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
