Lost My Clipbook cant turn it on, cant restore CA called scvhost.exe a virus so deleted it
  • mog_yosiah Sep 05, 2008
    Restore and a Bunch of my services are disabled and um not able too
    turn back on Thanks Sandrew 4 yur help though can u give any more
    help ?
    Ok Thanks 4 the speedy reply Sandrew
    President:
  • 2,961 Answers
Remove the virus with anti virus software, then go to start>programmes>accesories>system tools>system restore and choose a date before this happened, when it is restored, turn off system restore as you would have reinstalled the virus, re run the anti virus then turn system restore back on.
Posted on Sep 03, 2008
  • andrew pester
    andrew pester Sep 05, 2008
    It seems as if your registry is damaged beyond repair, you are going to have to get hold of a copy of windows to repair your operating system, althogh a complete format and installation is recommended, but use your own product key code on the label on your pc if you don't own your own copy that is
Think point security screen comes up and I cant get access to the internet. how do I fix this?
This a virus! If you don't have important files better to revert it back to factory settings. When the system restore option is still accessible you can try this as a quickfix
If you're a computer savvy person try deleting these files and entries, else call IBM Thinkpad software support: %UserProfile%\Application Data\hotfix.exe %UserProfile%\Application Data\thinkpoint.exe
Remove the following associated registry entries:
HKEY_CURRENT_USER\Software\PAV HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "thinkpoint" HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon "Shell" = "%Documents and Settings%\[UserName]\Application Data\hotfix.exe"
Feb 21, 2011 | IBM ThinkPad T40 2374 Notebook
Tip
How to remove the scvhost.exe Virus.
Svchost.exe is the name of a generic host process for services that run from dynamic link libraries (DLLs). A variety of worm malware programs spread a similarly named file <b>Scvhost.exe </b>via Yahoo! Messenger that blocks the Task Manager and Registry Editor, as well as use of the command prompt.<br /> <br /> <b><u>Warning</u></b><br /> Manual removal of Scvhost.exe may be very difficult as the removal process requires knowledge of the Operating System's command prompt and Registry Editor. If not performed properly, your computer system might experience permanent damage. Consequently, manual removal might be best for experienced users. Less experienced users might want to consider using an automatic spyware removal application, such as that offered by Trend Micro. This worm duplicates itself to different locations of shared folders. The duplicated program uses a folder icon that has an .exe file extension. DO NOT double click on any of these folders.<br /> <br /> <b><u>Follow these step by step instructions to remove the scvhost.exe virus.</u></b><br /> <b></b> <br /> <b><u>Step 1 (Turning off System Restore)</u></b><br /> This is so that if you ever need to use System Restore after you have removed the virus, it doesn't restore the virus aswell.<br /> <br /> If the operating system of the infected computer is either Windows Me or Windows XP, turn off System Restore while this fix is being implemented. To turn off System Restore within Windows Me, click <b>Start &gt; Settings &gt; Control Panel</b>. Double-click <b>System</b>. Select F<b>ile System</b> from the Performance tab. Left click the <b>Troubleshooting</b> tab and check the <b>Disable System Restore</b> box. Click <b>OK</b>. <br />To turn off System Restore within Windows XP, log in as Administrator and click <b>Start</b>. Right click <b>My Computer</b>" and select <b>Properties</b> from the shortcut menu. Check the <b>Turn off System Restore</b> option for each drive on the System Restore tab. Left click <b>Apply</b> and <b>Yes</b> to confirm when prompted. Click <b>OK</b>.<br /> <b></b> <br /> <b><u>Step 2 (Run in safe mode)</u></b><br /> Restart your computer in Safe Mode and log in as Administrator. Press <b>F8</b> after the first beep occurs during start up, before the display of the Microsoft Windows logo. Select the first option, to run Windows in Safe Mode from the selection menu.<br /> <b></b> <br /> <b><u>Step 3 (Accessing Command prompt)</u></b><br /> Access the command prompt. Click <b>Start &gt; Run</b>. Type <b>cmd</b>. Click <b>OK</b>. Then in the command prompt type <b>cd </b>to<b> </b>change directory then press the space bar. <br />Type the name of the full directory path of the folder containing your Windows system files. It will be either <b>C:\Windows\System </b>or<b> C:\Windows\System 32</b><br /> <b></b> <br /> <b><u>Step 4</u></b><br /> From the command prompt, type the following to unprotect the files for removal:<br /><b>attrib -h -r -s scvhost.exe</b> and press <b>Enter</b>;<br /><b>attrib -h -r -s blastclnnn.exe </b>and press<b> "Enter</b>;<br /><b>attrib -h -r -s autorun.inf</b> and press <b>Enter</b>.<br /> <br /> <b><u>Step 5</u></b><br /> Delete the files by typing the following from the command prompt:<br /><b>del scvhost.exe</b> and press <b>Enter</b>;<br /><b>del blastclnnn.exe</b> and press <b>Enter</b>;<br /><b>del autorun.ini</b> and press <b>Enter</b>.<br /> <b></b> <br /> <b><u>Step 6</u></b><br /> Type "<b>cd\</b>" to return to the main Windows directory.<br />Unprotect and delete the Autorun.inf file by typing the following from the Windows directory command prompt:<br /><b>attrib -h -r -s autorun.inf</b> and press <b>Enter</b>;<br /><b>del</b> <b>autorun.inf</b> and press <b>Enter</b>;<br />Type <b>regedit</b> and press <b>Enter</b> to open the Registry Editor.<br /> <b></b> <br /> <b><u>Step 7</u></b><br /> Locate the following entry:<br /><b>HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run</b>.<br />Delete the incorrectly spelled Yahoo! Messenger entry with the value<br /><b>c:\windows\system32\scvhost.exe.</b><br /> <b></b> <br /> <b><u>Step 8</u></b><br /> Locate the following key:<br /><b>HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon</b>.<br />Within the key, there is a <b>shell</b> entry with the value of <b>explorer.exe, scvhost.exe</b>. Edit the entry to remove the reference to Scvhost.exe, leaving Explorer.exe as the remaining value in the registry entry.<br /> <br /> <b><u>Step 9</u></b><br /> Locate the following key:<br /><b>HKEY_LOCAL_MACHINE&gt;SYSTEM&gt;CurrentControlSet&gt;Services&gt;<br /></b>Delete the following subkeys from the left panel:<br /><b>RpcPatch</b><br /><b>RpcTftpd <br /></b>Exit the command prompt and return to the operating system. Type <b>Exit</b>, and press <b>Enter</b>.<br /> <br /> <b><u>Step 10</u></b><br /> Reboot the PC.<br />If Scvhost.exe still resides on the computer, repeat these steps or try using an automatic removal program from McAfee or Symantec.<br /> <br /> <br /> <br />
on Feb 25, 2011 | Computers & Internet
I have lost ALL of my taskbars!! How do I get them back?
A program called explorer.exe controls the display of your taskbar and desktop icons. If for some reason it goes missing (you may have killed it using Task Manager, for example, or something more sinister like a virus has deleted it from your processes), then try this first:
  1. Open Task Manager (press Ctrl+Alt+Del, then click Task Manager).
  2. On the Applications tab, click New Task at the bottom right of the window.
  3. Type explorer.exe, then click OK.
If nothing sinister caused it to disappear, it should all come back as it was and you can stop panicking, breathe a sigh of relief, and continue working.
If that doesn't work, then try this:
  2. Go to the Processes tab.
  3. Click on the Image Name column header to sort the list alphabetically.
  4. Find all explorer.exe processes - select each, then click End Process for each one.
  5. On the Applications tab, click New Task at the bottom right of the window.
  6. Type explorer.exe, then click OK.
Are you using snagit, try to uninstall it and then check if you still get the errors. If you donot use snagit then there would be another error.
If you cant access control panel use the "Windows Key+R" on the keyboard which opens the run dialog and type in 'sysdm.cpl' which opens the control panel.
You could also try to restore you windows using System Restore and select a date of the backup when the computer was working well.
Make sure you do a complete virus scan with a good antivirus with updated virus definitions as it could be a virus too.
Jan 21, 2011 | Computers & Internet
My computer is frozn up with this virus on the start page i cant get on the start page for the child pron virus
Find clean pc and a usb stick. THEN GO HERE:
WWW.MALWAREBYTES.ORG AND DOWNLOAD THE FREE VERSION. SAVE TO DESKTOP. IT WILL SHOW UP AS MBAM.exe. BEFORE DOING INSTALLATION,turn off system restore and RENAME mbam.exe TO winlogon.exe
INSTALL, UPDATE, AND RUN FULL SCAN. DELETE EVERYTHING IT CATCHES AND REBOOT.turn system restore back on and create new restore point.
THEN DOWNLOAD NEW ANTIVIRUS. iF YOU CAN'T AFFORD TO BUY YOU CAN USE AVAST FREE VERSION AND ZONE ALARM FIREWALL FREE. OR YOU CAN SURVIVE FOR MONTHS ON FREE TRIALS OF KASPERSKY, WEBROOT, BITDEFENDER, AVG, AVAST, ETC, ETC.
GOOD LUCK AND IF I'VE HELPED PLEASE CONSIDER GIVING ME A GOOD RATING.
THANKS AND GOOD LUCK.
Oct 21, 2010 | E-Machines eMachines Desktop PC
Msn.exe error
Well reinstalling the program will help, and should not overwrite you setting or personal data.
Apr 04, 2009 | Microsoft Windows XP Home Edition
Hi masters: My computer go realy slow,when you stop using it for 10 min.I have installed a CA security anti virus,etc ,but still reporting one virus that the CA anti,hasent been able to clean so...
You need to find the path to where the virus file is located & delete it you're self. You're antivirus software should show you where it is located. Once you delete the virus file, shut down the PC. Unplug the power cord from the PC. Open you're case & remove you're memory. Wait about 15 seconds & reseat you're memory. (make sure you're memory is seated correctly).
Removing the memory clears the memory from memory virus).
Close you're case & reconnect the power cord. Boot the PC. Once windows has finished loading run windows diskClean, than run windows defrag. (may take some time). After defrag has finished restart you're PC. Run another virus scan. If you're virus software still finds a virus or you're system & its still running slow the virus may have damaged windows files or windows registry. A reinstall of windows may be needed. If you have system restore turned on than the virus is most likely being stored in one or more restore points.
Remove infected files that you cannot clean in the System Restore data archive. To completely and immediately remove any infected file or files in the data store, turn off and then turn on System Restore. To do so, follow these steps:
1. Click Start, and then click Control Panel.
2. Click Performance and Maintenance, and then double-click System.
3. Click the System Restore tab, and then click to select the Turn off System Restore for all drives check box.
4. Click OK, and then click Yes to initiate the restore point deletion.
To turn on System Restore again after the restore point deletion has completed, repeat these steps, but click to clear the Turn off System Restore for all drives check box.
Good Luck!
Mike
loadTOCNode(2, 'summary');
Apr 13, 2008 | Computers & Internet
Windows cannot find scvhost.exe
This is the Internet Virus , to overcome this , you may kindly be taken following steps .
Step 1: Write click on the start button task bar .
Step 2: Select Task manager by left click of you mouse.
Step 3. Under the process option , select line
svchost.exe system Administrator
Step 4. Select End process .
Step 5. Repeat Step 3 & 4 until the end of the bellow message.
svchost.exe System Administrator
Step 6. Close the Windows Task Manager by click X button .
or
Run the Original Quick Heal / AVG antivirus software in your system .
The steps are the solution for your problem.
OK
nilamani
nkjbbsr@yahoo.co.in , nkjbbsr@rediffmail.com
Dec 21, 2007 | Microsoft Windows XP Professional for PC
Windows cannot Find SCVHOST.exe.
Boot from your Windows XP disk and use recovery console, follow the onscreen stuff and put the admin password in that you setup when you installed windows, you should now be at a prompt EXAMPLE: C:\WINDOWS>
At the end of the prompt type: cd F:\I386
F is the letter of the drive where your XP disk is so you will need to change it to your drive letter. The prompt should now be F:\I386>
After the prompt type: Expand svchost.ex_ C:\windows\system32
C is the letter of you HD were windows XP is installed, needs to be changed accordingly. At the prompt type: exit
Your sytem will re-boot and you will now have a copy of svchost.exe in your system32 folder again.
If you have found this solution helpful please rate it as Solved, otherwise please ask again.
Thank you
Nov 01, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
