Question about Dryers
Hotpoint washer/dryer will not dry properly - Does it make a difference when connecting to an instant hot water system?
This should not make a difference. it is more likly to be a blocker up fan or lint is trapped in the duct. you can try clear this out by opening the unit up. should this fail order a new dryer duct and this will most definatly solve it.
Posted on Sep 15, 2008
Aquarius 1200 washer/dryer WD62. Why isn't it washing/rinsing clothes properly?
If your washer /dryer is correctly connected to hot and cold water supplies, replacing the fill valve would be a good place to start.
Mar 26, 2016 | Hotpoint Washing Machines
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hotpoint Aquarius WDD440 washer and dryer
Possibly Pump blocked. or impeller broken. without taking a proper look but sounds the obvious.
Jul 26, 2009 | Hotpoint Aquarius WD63 Front Load...
Where do I drain the tumble dry water on a hotpoint wd62 wash/dry
remove the top panel by unscrewing the 3 screws at the back of the washer dryer . remove the top and then remove the back metal panel. the screws are down the side and all around the back of the panel. once you have removed the panel check for the black rubber hose that connects to the drum. remove the clip holding the rubber hose by prising it with a small screwdriver. be careful as the water will flow out quite quickly. Check the hose pipe for any blockages and clear as required.
Jan 04, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryer not drying - also lets in water
does water also come in when the machine is off, if so then a solinoid at the back where the hot and cold water pipes connect to it...
However i need more information to give you a perfect solution...
hope this helps get back to me if it dont ill try my best...
Jan 17, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
Top Dryers Experts
