Question about Denon Audio Players & Recorders
Denon AVR 1804 Switch on and the display comes on but goes out after about 10 seconds. Whilst the display is on, the on/standby light flashes. After the display goes out the on/standby light still flashes only faster. Have disconnected everything but still does it
  • 3 more comments
  • lukey123 Sep 03, 2008
    Switch on and the display comes on but goes out after about 10 seconds. Whilst the display is on, the on/standby light flashes. After the display goes out the on/standby light still flashes only faster. Have disconnected everything but still does it. Screen goes off after third flash and saying reciever
    President:
  • 624 Answers
I fix these receivers for a living and can tell you with certainty that the problem you have is one that will require the replacement of several parts. You will need to know how to solder and be able to purchase the proper parts.
There are 3 different most common reasons that they go into the protect mode, which is what is happening to your unit now.
1. Has a blown output channel in the amp that will require the replacement of both output transistors of the bad channel and the replacement of several resistors and a coupld of other transistors and a capacitor in the affected channel. You wil lneed a multimater to be able to check and findout which channel is bad. I can supply you with the part numbers you will need for the repair if you plan on doing it yourself.
2. A voltage regulator in the power supply is bad. They have several voltage regulators and it is a common problem for one to go bad. Once again you will need a multimeter to check and find which one it is and then get the part and replace it. I can supply the part numbers for you if needed.
3. A resistor that supplies the amplfier circuit has opened up and needs to be replaced. This is the least expensive repair, but not as common as the other two. Only one resistor would need to be replaced. You need a multimeter to verify that it is bad, I can tell you which resistor to check and loet you know by the readings with the meter if it is bad.
Those 3 problems are the most common reasons for the receiver to shut down like your is doing. I work at an authorized Denon repair center and have repaired hundreds of Denon recievers so I am certain that the problem you have is one of these three listed.
Let me know if you plan on trying to fix this yourself and I will guide you thru the repair and even email you the service manual for a reference to do this repair. It is not an easy job, but it is the problem you are having. As I said before, I fix these receivers all the time myself, and I know how to fix them. Let me know if you want further help with this.
Dave
Posted on Sep 03, 2008
  • 1 more comment
  • Dave DeGain
    Dave DeGain Sep 03, 2008
    The repairs for these receivers normally run from $100 to $200 depending on which problem is the cause. Your receiver is about $500 to $800 brand new, so it is worth repairing.
    Resetting the unit will not help, there is no special sequence of flashes that will tell you anything about the error. it is going into protect mode for one of the three reasons I listed above.
  • Dave DeGain
    Dave DeGain Sep 08, 2008
    Did you ever read my solution to your problem? I actually have hands on experience with Denon's and can give you the form you need with the address to ship it to if you decide that is what you will do.
    I know you had hoped for a solution that you could do yourself, but some things just can't be fixed without a service technician. If you have some experience with electronics, I could actually guide you thru the repair. Nobody else that I know of here at FixYa! could do that. I may wrong, but I have seen no proof of anybody else here having the hands-on experience with these Denon's as I do. I even have the service manual in PDF format that I can email to you. It won't tell you what is wrong, but it has schematics and board diagrams that would help you to locate the bad parts that must be replaced to fix your unit.
    To do this yourself you would need a multimeter and soldering iron. As well as some solder and solder wick (to remove solder from the bad components that must be replaced).
    It would be appreciated if you would respond with an update and rate this solution.
    Thanks,
    Dave
  • chuck starck Apr 03, 2013
    Just found this thread. Thanks for all your time in assisting everyone. I'm an old tech from 50's and have serviced about anything electronic. I have found in my Denon avr 1804. one channel has shorted outputs, 4 .22ohm resistors and a .47ohm resistor, these are all open. Don't know the wattage. They look like metal film 1watt for the .22's and perhaps a 1/4 watt .47. Not sure. Also don't know the process to balance the output without the manual. So asking for resistor wattage and if you have the pdf, that would be neat. Don't know how we accomplish this. Also have read that there is a resistor change in the power supply, questioning that as well
    Master:
  • 521 Answers
Its the problem of over voltage or a faulty --ic--.get repaired .no other option.it will work and wont cost u much.
pls do rate the solution
thanks.
regards.
fixya expert team
  • 1,879 Answers
It seems that this product (and it's kins) have an issue.
Read this post
  • 89 Answers
Try to reset it
To re-set the 2802, just do as follows:
1. Switch off at unit's main power switch.
2. Hold A & B buttons and turn power back on.
3. Check entire display is flashing at approx. 1 second intervals, release the 2 buttons, microprocessor is now initialized.
Hope this helps.
  • 10,594 Answers
Your receiver has problem in Amplifier section and that's why shifted to safty mode to avoid further damage. Please contact nearest Denon service outlet for proper repair.
Regards,
  • Shahid Electronics
    Shahid Electronics Sep 03, 2008
    Denon Support might help you to locate nearest service dealer.
    Already explained to you that your receiver has problem in Amplifier section and qualified tech person from Denon will handle it because receiver might need some defective parts replacement. It doesn't seem issue of wrong settings. Please contact above said Denon Service link.
    Regards,
    President:
  • 1,263 Answers
You have an internal issue that can't be repaired by you. my suggestion is either take it to the place you bought it if it is under warrenty and have it replaced or take it to a repair shop. however it might cost as much to repair it than to get a new one.
  • Ronald Mueller
    Ronald Mueller Sep 03, 2008
    well gees you guys are just rich. i told him the first time out that it needs to be repaired it's just common sense
  • Denon Master
  • 19,396 Answers
Try unplugging the power cord for ten minutes, see if this clears the error. If it flashes a number of times tell me how many time the ligjht is flashing
  • Ginko
    Ginko Sep 03, 2008
    Try also keeping start button pressed for ten seconds.
  • Ginko
    Ginko Sep 03, 2008
    Your stereo has a safety switch device that keeps the unit off when it detects a short, a faulty component or an overvoltage.
    If you want to do it yourself you need to take it apart and to test, multimeter in hand the components, starting from power adapter section and amp.
    If you do not get any error code the unit must be tested dirtectly.
I have a old denon avr-1804. try to switch on power but can not. just appear a main power red light flashed rapidlly. please tell me why?
Greetings
the red flashing LED is that the Device is in protection mode.
the internal power supply . +15 volts and -15 volts are defected you need to be replace it ... Regulators 7915 and 7815 .... these you should change , might also need to check capacitors .
these are common defects for Denon . AVR units.
Good Luck
Hope this helps
May 26, 2016 | Denon Audio Players & Recorders
Zone 2 on my Denon AVR 1804 only works with an analog input. Apparently it was designed that way. WHY?
Because in order to use a digital input, the unit would have to completely power on. Zone 2 is designed so that it can be used with the main power off.
Sep 27, 2013 | Denon AVR-1804 Receiver
How to connect Denon avr 1804 connecting to roku hd
I connected by Roku to a Denon 1804 Receiver this way:- I plugged the cable that came with the Roku into VCR2 input jack of the Denon. (I used VCR2 because it was available).- Using the remote from the Denon, I made sure the slide switch was on "Audio." (See page 20 of Denon Manual).- I pressed pressed the System Setup button- *System Setup appears in display of Denon- Using the cursor buttons I scrolled to menu Digital in Assignment- I set Menu item 16 Coaxial to VCR2 since that was the input jack I used for the Roku. - After making the selection press the CH Select Enter button to save- To exit the System Setup press the System Setup button again- When using the Roku, select the input source as VCR2 (or whatever jack you used). You should now have sound through the Denon.The most important step is to read the Denon manual starting on page 20
Dec 08, 2012 | Denon AVR-1804 Receiver
Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Dec 28, 2009 | Denon AVR-1804 Receiver
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
Unit keeps shutting off
Protection circuit activating. Possibly a shorted amplifier channel or power supply fault. Take it to a Denon repairer
Jun 02, 2009 | Denon AVR-1804 Receiver
No display; No power
Your unit has a hard short in it. This is usually a power supply problem. Most likely the rectifier has failed. This should be a relatively simple and inexpensive repair. Figure on $10 for parts plus the local labor rate.
Dan
Jul 16, 2008 | Denon AVR-1804 Receiver
Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Jun 27, 2008 | Denon AVR-1705 Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
340 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
