HP Photosmart C6380 All-In-One InkJet Printer Logo
Posted on May 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just purchased the HP Photsmart Plus B210 series. I followed there set up process, but everytime I power on the printer, It reads "0x61011beb There is a problem with the printer or ink system. Turn the printer off, then on. If the problem persists, refer to printer documentation." I have tried turning it off, unlplugging everything, and replugging in everything. I have tried plugging it into the wall instead of the power strip. Nothing helps, always the same messge. please help!
Terry Weaver
Level 3:
Master:
  • Master 412 Answers
  • Posted on May 28, 2017
Terry Weaver
Master
Level 3:
Master:
Answers
412
Questions
Helped
120111
Points
1235
Suggest you return it and buy Canon or Epson
5 Related Answers
Anonymous
  • 152 Answers
  • Posted on Mar 29, 2008
SOURCE: HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Anonymous
  • Posted on Oct 05, 2008
SOURCE: Help!!! BEWARE SPAM NUMBER BELOW 1-800-532-4187
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
Joed911
JDTec
  • 4338 Answers
  • Posted on May 21, 2009
SOURCE: Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Aug 19, 2009
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
Ben Johnson
  • 686 Answers
  • Posted on Jan 19, 2011
SOURCE: My printer keeps saying "Ink
Have you tried these solutions?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204785&tmp_track_link=ot_search
Printer does not reconize paper loaded HP B210
try this. the hp way with video- please mail back if this doesn't work
My printer HP photosmart plus B210 series displays error message
>> Remove the print head and gently clean the head.
>> Check is there any obstructions on it.
>> Turn Off the printer for 2-3 minutes and turn On.
>> Re-insert the print head and check the status.
It may help.
Error code 0x61011beb
This seems to be Printer failure error. The best you can expect the printer to work is with the steps below.
Remove all the cartridges from the printer. Wipe the electrical ( tiny golden contacts ) with Lint free cloth. Disconnect the power cord from back of printer and while holding the power and cancel button - connect the cord. Release the buttons after 2-3 seconds.
It should prompt you to install cartridges. Hope everything goes smooth, if not it could be hardware related issue. You can also contact HP on 1-800-474-6836 for further information.
Regards,
Sean
I hav recently purchased a new printer HP PHOTOSMART PLUS B210 Series. I am having trouble integrting the printer tomy wireless network. The printer is asking for a WPA PASSPHRASE, but i cannot locate my...
Do you know the password to your WiFi-network? (that is the WPA passphrase)
i you have forgotten the password, you can change it by logging on to your router and settings a new wifi password.
you can find out your routers adress if you go to start - run.. and type in cmd and hit enter there you get a black screen, type ipconfig /all (followed by enter) and look for default gateway (thats the adress to your router)
often http://192.168.0.1
Nornal all in one HP Printer quote with options
We can purchase deskjet F4100 all-in-one or photsmart C5288 all-in-one.
k24674
Grand Canyon Tech
Grand Canyon Tech
