Question about Vtech Lands Phones
Vtech cordless phone not working.I've 2 handsets.Not able to make a call or receive a call. I get following msg "Other handset is on or out of range" what could be a problem?
  • Anonymous Jan 18, 2009
    I've got the same issue. This phone is a junk!
AlmostBob
  • 550 Answers
SOURCE: Vtech ia5870 dual handsets model problem:
http://www.vtechcanada.com/manuals/5870ciben.pdf
from the troubleshooting section of the manual
• Unplug the base unit’s electrical power and remove the battery from the handset. Wait for 15 seconds then plug in the battery place the handset in the base unit and plug in the power. Allow up to one minute for the cordless handset and base to synchronize
not a guarantee, something to try
Posted on Aug 30, 2008
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Posted on Jul 06, 2008
SOURCE: My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
Posted on Sep 20, 2009
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Posted on Oct 09, 2009
SOURCE: 5.8GHz Cordless Phone with Digital Answering System & 4 Handsets: my vtech cordless phone says connecting and i can'...
my vt phone is lock and need to unlock it help
Posted on May 19, 2010
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
Jan 21, 2016 | VTech Communications CS6114 - cordless...
My vtech phone say not registered and see manual #cs6114
VTech Communications Inc.My handset displays Not Registered. ... If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in ...
My vtech phone says not registered and not sure why ... - Fixya
www.fixya.com/support/t10092346-vtech_phone_says_not
Aug 13, 2011 - my vtech phone says not registered and not sure why and how come? can ... See page 26 of the manual for detailed instructions on HOW TO ...
My vtech dect 6.0 phone says not registered how do i fix it ...
www.fixya.com/.../t7993579-vtech_dect_6_0_phone_says_not_registere...
Jan 26, 2011 - my vtech dect 6.0 phone says not registered how do i fix it - VtechDECT 6.0 ... If you click on the above it will take you through to the manual, hope i`ve helped .... See all Vtech DECT 6.0 Digital Cordless Phone Questions ...
? 3:21
My phone says no line plz help me. Been without a ... VTechuser manual had no instructions to set up an ...
[PDF]User's manual - Vtp-media.com
Feb 10, 2015 | VTech Communications CS6114 - cordless...
My vtech phone says not registered and not sure why and how come? can this be fixed or do i have to buy new one? model # CS6114 S# LR605935851
Here is a direct link to the User's Manual for your phone:
http://vt.vtp-media.com/ecp/documents/product_Product/1624/UserManual/5352/cs6114_manual_i6.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 26 of the manual for detailed instructions on HOW TO REGISTER THE HANDSET TO THE BASE.
Basically, the manual reads as follows:
Not registered appears on the handset and it does not work at all.
The handset may be deregistered from the telephone base.
Follow the steps below to register the handset to the telephone base.
1. Remove the handset from the telephone base.
2. Press and hold FIND HANDSET button on the telephone base for about four seconds until the red IN USE light turns on.
3. Then press # (pound key) on the handset.
It displays Registering... and it takes about 60 seconds to complete the registration.
The handset displays Registered for a few seconds and you hear a confirmation tone when the registration process completes.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 13, 2011 | Vtech 2653 Cordless Phone (VTECHEV2653)
LI misplaced my handset How does the "locate
The locate handset button will make the missing handset ring for 60 seconds. This will usually give you time to find it (assuming the handset battery is good, the handset is not out of range, and/or the handset ringer isn't set to OFF). Once you have the handset, press the Page/Handset Locator button or place the handset on the base.
You can press the locate handset button again if you haven't found the handset in one minute. The manual for the Vtech 2451 is available from Retrevo: http://www.retrevo.com/support/Vtech-t2451-Telephones-manual/id/470ag516/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(If you have a large area or several floors to check, those 1 minute intervals aren't enough time to search for one person. Enlist assistance if you suspect the missing phone isn't just under a throw or pillow near the couch (for example).)
Jul 01, 2011 | Vtech 2451 Cordless Phone
Cannot make conference call does my phone has that facility model #CS6229-2
The VTech CS6229-2 - cordless phone has a two handset systems provide the convenience of operating two handsets using only one phone jack and one base station. The second handset simply needs an electrical outlet to plug into. These systems also allow you to transfer calls, conference an outside call or use the intercom feature between handsets.
Here's an online instruction manual for your guide: http://www.manualowl.com/m/Vtech/CS6229-2/Manual/196794
Jun 28, 2011 | Vtech i5866 Cordless Phone
I have a cs6328-3 model vtech digital ans system. It is only 1month since purchase. the three handsets are the original handsets and i have no additional handsets that were added. Error: out of range / no...
Periodically, while using my Vtech Model CS6328-3 phone, it becomes virtually impossible to hear the other party - interestingly, it affects other non-cordless phones in the home at the same time. Just like that, the volume may come back. The person on the other end sometimes has the same proble hearing me - but not always. Have switched back to a previous Panasonic phone system in the interim, no problems. Seems to be the Vtech system. Any thoughts?
Mar 20, 2011 | Vtech DECT 6.0 Digital Cordless Phone
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
VTECH LS6125-2
The 6125-2 only supports 2 handsets.
Oct 29, 2008 | Vtech LS6125-2 1.9 GHz Twin 1-Line...
Lands Phones Logo
246 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
