Question about Konica Minolta DiMAGE 5 Digital Camera
What is the difference between Type-I and Type-II Compact Flash?
    Master:
  • 425 Answers
The size of Type-I is 36.4 (H) x 42.8 (W) x 3.3 (D) mm, which is the most popular type of Compact Flash card. On contrary, Type-II is 5.0mm in thickness. Some Type-II is designed not only for data storage including hard disk memory, but also for special purposes such as LAN or MODEM card, or parallel or serial connection.
Posted on Sep 15, 2005
3 Suggested Answers
SOURCE:
toto
  • 425 Answers
SOURCE: What is the difference between Type-I and Type-II Compact Flash?
toto
  • 425 Answers
What is the biggest size memory card for my Dimage A1 Minolta Camera?
An older camera, the DiMage A1 came with a 16mb card. Some cameras are picky about which cards work best. Compact Flash cards are sold in different speeds and your camera may work faster with a faster card. This camera can use Compact Flash type I or type II, and is compatible with the microdrive card. Since this camera was introduced the capacities of Compact Flash cards have increased dramatically so I believe you should be able to use a larger card with no problems but I would check out some of the online photography sites to read about other's experiences. Here is one good resource:
http://www.imaging-resource.com/
Hope this helps!
Sep 13, 2016 | Minolta Cameras
Out of Memory?
Check the camera. Many older cameras cannot use the newer larger than 2GB memory cards. If your camera cannot us the UDMA type cards you will have to buy a smaller card.
Nov 18, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
I bought a 2 gb compact flash card. Are these not
It appears that the 9700 works with Type II CFD's.
I think that the 2 Gb cards are ULTRA II's which likely will not work with your 9700. The 512's are getting harder to find as well...
Nov 10, 2009 | Janome Memory Craft 9000 Computerized...
What size compact flash card can i use in a olympues e500 can i use a 8GB CF card
You should be fine using an 8g card, but do however make sure it is a type I or II and although you asked about compact flash I might add that the XD M type cards are cheap BUT extremely slow so be careful what you go with. Where ever you get the card from check their return policy just in case there is an issue with it. Also might want to enusre your firmware is up to date before you try newer cards.
Jul 19, 2009 | Olympus EVOLT E-500 Digital Camera
Compact flash card
It can if it is compatible, meaining I use the Canon and I have to use the type II cards, it accesses fine.. I wouldn't go to the type IV as I have heard they hang when acquiring pictures.
Jan 29, 2009 | Nikon Coolpix 5700 Digital Camera
Can I print images directly on printers capable of card direct printing via the Compact Flash in which images captured with the camera are saved?
In general, you can print the images captured with the camera directly via Compact Flash card on any printer specified to accept Compact Flash type I and II. Please contact manufacturer of the printer for technical details.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Sep 15, 2005 | Konica Minolta DiMAGE 2330 Zoom Digital...
Sep 15, 2005 | Konica Minolta DiMAGE 2300 Digital Camera
Microdrive compatible?
The microdrive is compatable with anything that supports reading compact flash memory cards, because there is a common method of communication between flash and hard drives that use pcmcia or CF slots.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Media cards
You can use Compact Flash cards (Type I and II) and Microdrive. By connecting with the CF Card adapter (MACF-10), xD-Picture Cards can also be used. Basically, you can use any manufacturer's Compact Flash Card in EVOLT E-300. The following Microdrive cards are verified as compatible with the E-300 camera: DSCM Series - DSCM-10340, DSCM-10512, DSCM-11000 3K4 Series - HMS360402D5CF00, HMS360404D5CF00
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Konica Minolta DiMAGE 5 Digital Camera Logo
48 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
