Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY TRINITRON KV-28FX68U TV
I have recently moved house and now my TV comes on fine but then it will change to the AV2 channel, you can turn it back but the same thing keeps happening. Before moving my DVD, Sat & Nintendo all worked through the TV, now none of them do. Any ideas before I buy a new one.
  • 556 Answers
SOURCE: Sony Trinitron KV-1670 TV
go to web site www.serviceinfo.com it is available you will have to download.
Posted on Sep 29, 2007
SOURCE: SONY TRINITRON MODELO KV-21XME
Hello pls tell me number of sony kv 21m53 tv H out number i am shihan.....
sshihan@gmail.com
Posted on Aug 07, 2008
  • 147 Answers
SOURCE: Channel Display,Upper Right Corner of Screen
Should be a display button on the remote. If you don't have the original remote you might be s****ed.
Posted on Mar 30, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 208 Answers
SOURCE: how can i turn on the av channel on a sony trinitron KV-25F1U
Hi, look for a symbol either on the front of the TV or remote that shows a Circle with an arrow pointing into it from the left
Posted on Mar 21, 2010
Testimonial: "thank you so so much, so simple but I dont have an instruction manual. Many, many thanks. Angie"
Sony Trinitiron 27 inch. It's stuck on channel 27
go to menu then channel turn off channel fix that might help ya
May 24, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
My remote worked fine, but suddenly won't work at all. TV is older Sony Wega 24" Trinitron (KV-24FS100). The satellite remote will change the channels, cause it's using the box, but it won't control...
Could be the IR receiver in the TV.
Make sure nothing is in front of the TV that would block the IR from receiving commands from the remote, I've seen customers put VHS tapes on the front of their TV that caused the remote to not to work.
Good luck
N Sabre
Nov 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony trinitron kd28dl10u has moved house. retuned digital channels but itv and channel 4 are missing?
i think i get the jist - you've moved, and now you're missing a couple channels. from what you're saying, i assume you are using a digital converter box, or have a digital ready tv. i personally have seen many problems since the digital change, specifically loss of channels. even though digital tv is supposed to be 'all that', and it is fine when it works, the quality and placement of your antenna is still critical. you are still receiving a signal on the same channel, only with digital, they have reduced the bandwidth. this action was not done with the consumer in mind, it was done to free up air space for other communicatiomns. try an amplified antenna [available at radio shack for about 20 dollars], and try different positions. if this doesn't work, you might try an outdoor antenna. with digital signals, if there is an obstruction between you and the transmission site, rather than getting a weak, snowy picture, or shadows, as you would back in the days of analog, your receiver will simply not receive the station
Sep 05, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv repair
I have had 3 flat-screens so far, a Polaroid, Panasonic and now a Sanyo. In my experience when this happens, you would remove the back, clean and dust it carefully. If you have never done this before, it is very wise to leave it to the more experienced as the circuit board contains some sensitive parts. The circuit board needs to be looked over for any damage or burn marks. This could reveal the problem. Also, check for blown diodes. They are roughly shaped like a pencil eraser and should be flat on the top. If they are rounded or appear black, they are bad and need to be replaced. Again, if you've never done this, highly recommend leaving it to the more experienced. Hope this helps.
May 22, 2017 | Televison & Video
Sony trinitron tv KV-32LS36U changing channels
You may have a control button sticking either on your remote or on the front panel of your set. I have run in to this on several sets. When this happens, some really strange things will happen including problems like you're having. Stargazer
Jun 13, 2007 | GE 32GT660 32" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
