Question about Kenwood Car Audio & Video
I have a kenwood kna-dv2200 sat nav fitted to a kenwood kvt-m700 head,recently when i input a postcode/address and then select destination the screen shows where i want to go but then says "voice commands not available for this area" and won,t give me a route.If i leave the unit alone with no destination input it will show my posotion as i am driving.Any help much appreaciated as i am going on hal shortly and the sat nav will be much needed. Thanks Paul
  • 78 Answers
SOURCE: peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Posted on Dec 19, 2007
zzedly
  • 300 Answers
SOURCE: Adding MP3 Input to Kenwood R/C
To be honest, I can't find one spec of info on that stereo on the internet. It's possible the DIN connection you see is for controlling a CD changer. If so, it's possible you can use either this cable or this cable to turn it into an AUX input. But without a manual or anything, it's hard to know for sure. You have to contact Kenwood.
Posted on Mar 14, 2008
Lounatech
  • 23 Answers
SOURCE: I have a cd stuck
Have you tried hitting the "Reset" button on the head unit?
The procedure is on page 7 of the owner's manual under the heading "How to reset your unit"
Here's the URL for the Owner's Manual:
http://inform3.kenwoodusa.com/manuals/KVT-719DVD.pdf
Per the owner's manual, you're supposed to call Kenwood technical support if the display doesn't correctly reset or come back on and/or if the disc won't eject.
Posted on Apr 14, 2008
hogan doan
  • 227 Answers
SOURCE: My AVIC 9 sat nav
Assuming you have the original navi disc, then your laser eye is either dirty or tired(out of alightment) from playing mp3 or copied disc. Buy a cd lens cleaner kit if that doesn't help then have someone who know how and have it re-align. Goodluck.
Posted on Apr 24, 2008
SOURCE: new route
From Delphi tech support:
NAV200 SD Card Reformat
Problem:
Customer reports that the NAV200 has lost its voice prompts and/or constantly reads NEW ROUTE.
Solution:
Reformat SD card from FAT-32 to FAT. And replace files on SD card with back up files from DVD-ROM.
Reason for Problem:
The navlib.ini file located in the navigation files (in mnav) is missing from the SD card. It is located in mnav in the back up files found on the DVD-ROM
Posted on Jul 09, 2008
HOW DO I DELETE ADRESSES FROM BINATONE G350 SAT NAV
You can only delete the Recent Destinations and destinations in the Address Book, the Sat Nav will still store destinations you have entered and as new ones are entered the older ones will fall off the system when maximum is reached.
Apr 03, 2011 | Toymax Binatone Carrera X350 Car GPS...
What fitting is the external antenna is it mmxc?
I hope everybody visiting this webpage will find this answer useful.
First of all, ignore the antenna connector recommended within the RAC Sat Nav 200 manual, it's wrong.
What you need is the :
GPS Antenna 1M Length MMCX with a
180 degrees straight connector.
Make sure it's a MMCX straight connector.
Plug in the antenna and within half a minute of typing your postcode destination into the Sat Nav the reception will have been picked up.
Hope this saves everybody a lot of hassle.
David Coggon - Author of Children's Book ` Jack's Crayons '
http://www.ahstockwell.co.uk
Aug 04, 2009 | SNK RAC SAT NAV 200 GPS Receiver
Vw sat nav problem
There may be a setting somewhere to define your 'home' position. It will probably default to this location as standard until you find the setting and reset it to your own postcode/home address
Jul 07, 2009 | Car Audio & Video
Kenwood kvt m700 touch screen problems
You don't need a code, it's unlocked by the remote that came with the unit (small purple one)
Jun 26, 2009 | Kenwood KVT-M700 Car DVD Player
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
KVT-719 NAV button not highlighted unable to select
Well I see no help here, but emailed kenwwod and they told me:
The Garmin menu is not accessible from the main source select screen, only thru the V.Select which you have already discovered.
The reason why "NAV" is displayed as an audio source is if you were to add a GMX30 XM Radio/NavTraffic antenna, you would be able to access XM radio (subscription required). So unless you have the GXM30, you will never use that source key.
Jul 12, 2008 | Kenwood KNA-G510 GPS Receiver
Navigation not working
Recheck your connections on the kna-g510 and ensure it is getting power, not too familar with the kvt-819, but I've got the kvt -915 and when I pull up the screen, there is an icon right by the src icon, that looks like a wrench. Press that and find A/V interface and ensure that the navigation input is set to RGB, also you can back out and go to user interface and ensure the Navigation is set to auto intstead of manual. That may be the case if it is similar to the kvt -915.
Apr 20, 2008 | Kenwood KNA-G510 GPS Receiver
Installing kna-g510
You have to select your video source to GPS instead of the source in the main menu to GPS
Jan 22, 2008 | Kenwood KNA-G510 GPS Receiver
Kenwood kvt m700
The unit is clipping which means it's too loud, lower the volume and should be fine.
Jan 15, 2008 | Kenwood KVT-M700 Car DVD Player
Kna-g510 gps receiver not working
I have the same problem, did anyone get to fix it?
Jan 02, 2008 | Kenwood KNA-G510 GPS Receiver
Car Audio & Video Logo
99 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
