Question about HP OfficeJet 6110 All-In-One InkJet Printer
CARTRIDGE ALIGNMENT MY FAX SAYS ME TO PRESS ENTER FOR CARTRIDGE ALIGNMENT AND IF I PRESS ENTER IT SAY "PAPER DON'T MATCH" (PAPEL NO COINCIDE) ONE AND OTHER TIME AND NEVER CHANGES, SO... I CAN NOT ALIGN CARTDRIGES AND THE MESSAGE APPEARS ALL THE TIME.
  • 138 Answers
See my post on this issue under the link posted below. There are a couple solutions for this error and we are approaching it there.
http://www.fixya.com/support/t999608-align_cartridges_keeps_comming
Hope this helps you.
Posted on Sep 04, 2008
My printer is telling me to "press enter to align the cartridge". i did that but, nothing is happening. HELP!
Solution There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Follow the steps below to resolve the problem Step one: Examine the paper the alignment page was printed on The alignment page must be printed on clean plain paper of either letter or A4-size and that has a brightness level (as printed on the paper package) of at least 85. Colored papers or paper that already has printing on it will cause the alignment to fail. Back to top Step two: Does the alignment page print correctly For the HP PSC 900 series, if the page ejects immediately or a Paper mismatch or Paper too narrow message is displayed, the 4 x 6 paper tray selector located on the paper output tray is pushed forward. Move the selector all the way toward the front of the product. Look at the alignment pages that the product printed. Compare the alignment page to those that are included in the "Examples of alignment pages" section in this document. If any of the colors or the black is missing from your alignment page, a cartridge-related problem exists. Click here for information about troubleshooting ink- and cartridge-related problems (buu02176) (in English). Back to top Step three: Perform an print cartridge cleaning procedure The product can perform an print cartridge cleaning procedure even after the alignment message has displayed. Follow these steps to perform an print cartridge cleaning procedure at the front panel:
  1. On the front panel, press the Menu or Setup button (depending on the model).
  2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press the OK or Enter button (depending on the model).
  3. The Clean Print Cartridges message should display on the front panel. Press Enter or OK to begin the cartridge cleaning process.
A page will be printed during the cleaning process with all of the colors on it. If any of the colors (including black) are missing, faded, or streaked on the alignment page, there is a ink cartridge problem. Back to top Step four: Try to align the page again HP products have two methods for aligning the ink cartridges, fully-automatic and semi-automatic. The steps are different for each type. Refer to the information below to determine which alignment method your product uses. Automatic cartridge alignment Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
Aug 11, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do I align the cartridge after I replace it. The fax printed out a sheet and the lines are not straight. I went to tools...to align cartridge and then I am not sure how to adjust the lines
Follow below steps to complete alignment.
  • With the Cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place.
  • Close the cartridge compartment cover and control panel.
  • Press the Start/Enter button.
  • On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old
NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
  • An alignment page will print and 06 [01-11] will show on the display
  • Look at the alignment page and select the number under the straightest line, and then press that number on the keypad and then press Start/Enter .
Oct 17, 2010 | HP 1040 Plain Paper Inkjet Fax
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Says the paper is too narrow
Please find the solutions for your problem below:
DESCRIPTION AND SOLUTION – 1:
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.)
Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
DESCRIPTION AND SOLUTION – 2:
The media type sensor is out of calibration. HP has released a firmware update that corrects this problem.
1. Visit the Support and Drivers Web page and search for the driver downloads Web page for your product. To access to the Web Page click here.
2. Select your Windows version.
3. Locate and select the Firmware Update.
4. Follow the directions on the Web page to install the firmware update.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 26, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
NEED DRUM RESET INSTRUCTIONS
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Jun 24, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Printer error on sharp ux-b700 new cartridge?
Try to reinstall the cartridge and press NEW, then go through alignment process.
Dec 08, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  3. Press Enter .
  5. Press Enter .
  7. Press Enter .
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printing
The printer hp officejet v40xi is asking for a cartridge alignment. When I press enter the printer does nothing want take paper or engage the paper nothing
Aug 12, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
