Question about Mitsubishi VS-45607 45" Rear Projection Television
Picture The picture is roling. Is there anyway to manually adjust?
  • 927 Answers
Good Day, skieebumm;
There no adjustment. Try this: (MENU DOES NOT ROLL) CHECK C2A04, 10 UFD 50V OFF PIN 5 OF IC2A01 ON THE VIDEO PCB. 2. CHECK C2046, 47 UFD @ 50V OFF OF DL2001 ON THE VIDEO PCB. 3. (MENU DOES ROLL) CHECK C2B14 10 UFD @ 50 V NP OFF THE BASE OF Q2B02 ON THE VIDEO PCB. Good Luck, big IRISH.
Posted on Sep 04, 2008
Can't get picture too get any brigther ,,have bright adjustment all the way to bright
There are several brightness adjustments on this TV. Download the manual from the following link. Set the size to a readable %. Then click "Edit", then "Find", and type "bright", then click "Next" repeatedly to review all your brightness options. http://www.manualslib.com/manual/82813/Jvc-Lt-32e488.html#product-LT-37E488
Jun 28, 2014 | JVC 37" Lcd Tv - Widescreen [lt-37e488]
Z3 projector.3 years old. Blue tinge in one corner of projected picture. Grainy picture on dark scenes.
There may be some problem with your picture tube else try this that looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Jun 23, 2008 | Televison & Video
Picture is too wide to fit screen can not see complete picture
hi there, i don't know your TV brand but this could be of help anyway. there is an adjustment for horizontal and vertical width. you can manually adjust the setting until it fits the picture on the screen. for standard TV it has trimmer in the CRT board. If in your case you have a soft adjustment in the remote control try to adjust it. Learn how the menu works just look for the picture adjustment.
Good luck, please rate and vote.
Mar 20, 2011 | Televison & Video
Some channels have lost their sound. picture is ok, but no sound. this is rcab27tf680
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by SAP selected on your remote control. Make sure you have selected Stereo or Mono in the audio menu. You can find all of this in your owners manual ( which you can probably download if you don't have it). Good luck, John
Nov 22, 2010 | RCA B27TF680 27 in. TV/VCR/DVD Combo
I have a ViewSonic N2635w LCD TV and the picture looks so stretched out width wise. I don't see anyway to fix the picture with the remote. How can I change the picture to look normal?
there should be something in the menu where you adjust things. seems as your in wide mode or zoom mode. should be something there to adjust the picture.
Jun 10, 2009 | ViewSonic N3735W 37 in. LCD TV
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
http://servicemanuals.vstore.ca/
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Color settings
well that all depends on you . you can adjust anyway you like.
Jan 03, 2008 | Toshiba 37HL67 37 in. LCD HDTV
Picture is not centered
Geometry adjustments are done in the servicer menu by
skilled technicians only.Adjustment service calls can cost
around 150.00.......T.
Oct 21, 2007 | Toshiba 50H82 50" Rear Projection...
How to manually adjust the centering of the picture
On newer televisions the centering adjustment is only in the service menu. I wouldn't suggest anyone accessing it unless you understand all of the abbriviated alignments.
Feb 21, 2007 | Samsung TX-R2035 TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
