Question about Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range
Kenmore builtin oven model 911 4742990
Error 'F1' first flashed when power was connected and constant beeping. Was able to stop this and set the clock. When function is selected, and temp set, the panel shows the temp at 100 degrees. As it begins to heat, the readout goes out and oven goes out.
  • Anonymous Dec 01, 2008
    When using the oven error code F1 came up for a few weeks. At first it would stop working when pre heating the oven and after it cooled down it would stop beeping. Then a few weeks after that started the oven and view panel with clock and bake time just stopped working. I had recently cleaned the oven with the self cleaning feature. the stove is about 6 years old but barely used. Really disappointed with this product!
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
My stove has the same problem with a loud alarm for several seconds then post F1 in the clock field, the range still works Thank U.... please help SERGIO SANTANA 7-30-10.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jul 30, 2010 | Maytag MER5730 Electric Kitchen Range
I have a tappan range that keeps getting F1/F3 in on the display panel.
Mar 03, 2010 | Tappan TGF363 Gas Kitchen Range
Maytag Oven MEW5530BAW throws error F1 after cleaning the oven using the clean cycle. I had to manually unlock the door and tried to run oven afterwards but it is still throwing the error
Importatnt. few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 07, 2010 | Kitchen Ranges
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F1 error code and beeping on a ge doubleoven
Hello there:
Jan 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
Code F1
Dec 13, 2009 | Kitchen Ranges
What does error code f 1 mean on an electic range if i hit clear the beeping stops but comes back on in a few seconds
Copied from another website:
Jul 26, 2009 | Frigidaire Gallery GLGF389GS Kitchen Range
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Amana acs7270ax stove beeping and flashing panel
The F1 error code indicates a control board failure. You need to replace the electronic control board. Good Luck Please rate
Dec 18, 2008 | GE Spectra JBP78 Electric Kitchen Range
Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range Logo
634 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
