Hurricane Gustav just blew through Baton Rouge and we were without power for over twelve hours. When our power was restored the a/c felt wonderful and we were so grateful. The a/c ran well all night and then shut off this morning around eight o'clock. Is there a way to reset the unit? We have checked fuses, the pan in the attic is empty, we tried to just run the fan, but it wouldn't turn on. Any suggestions?
  • 51 Answers
Verify your outside breaker did not trip or the inside breaker. Reset once if it continues to trip have some one check it out. If you have a programable t-stat take it off the wall and remove the battery this will cause it to reset
Posted on Sep 08, 2008
Hurricane names
Mitch (1998), Katrina (2005), Wilma (2005), Ike (2008), Gustav (2008), Irene (2011), Jova (2011), Matthew (2016), Hermine (2016), Otto (2016), Irma (2017)
Sep 13, 2017 | Miscellaneous
What would be the best way to get to phoenix AZ from baton rouge la by bus
This is a example if you were leaving on the 18th of this month also I listed the amenities and the total time of trip.
Wi-Fi
Air Conditioning
Power Outlets Departure
Wed, March 18, 10:55 AM
Baton Rouge Greyhound Station
1253 Florida Blvd Arrival
Thu, March 19, 1:55 PM
Phoenix Greyhound Station
2115 E Buckeye Rd
Trip duration
1d 3h 0m
Mar 18, 2015 | Cars & Trucks
Power windows not working
"It is not likely that a fuse or relay will cause a single window to not roll up or down. More likely, the power window motor, door switch or window regulator has failed." AGCO Automotive Repair Service Baton Rouge LA Detailed Auto Topics...
Mar 03, 2015 | Cars & Trucks
Is the brake lamp switch output the same As the relay
No, the brake light switch is powered from a different fuse and when the brake light switch is activated, power from the switch activates the relay. The relay then takes power from the brake lite fuse or fuses and sends it to the brake lamps.
AGCO Automotive Repair Service Baton Rouge LA Detailed Auto Topics How To...
Feb 05, 2015 | Cars & Trucks
At speeds of 40mph starts chugging a bit wondering if it could be air filter or coil pack
first thing to try is the fuel filter, if its partly blocked some fuel will pass allowing for some speed, but after more fuel is needed it cant pass fast enough so your car will chug or act like its cutting out, my 94 explorer would run fine up to 35mph, but after that it acted like it didnt have power and even died a few times i changed the fuel filter and the issue went away AGCO Automotive Repair Service Baton Rouge LA Detailed Auto Topics What...
Feb 02, 2015 | 2003 Ford Focus
I reside in Baton Rouge, LA...Where is my nearest "Toro Service Center" to get my lawnmower repaired?
HIGHLAND HARDWARE 7460 HIGHLAND RD, BATON ROUGE, LA, US, 70808 Phone: (225) 766-3049, Fax :(225) 767-5747 Services Toro products regardless of where purchased.
Sep 10, 2010 | Toro Lawn Mower With Toro Power Tools
Truck Stalls when driving down hwy.
Check your air filter. Could be fuel pump as well
Mar 29, 2009 | 2004 Chevrolet Silverado
Supressor, transient
Hello hward,
Welcome,
You said, Hello from Baton Rouge, La. just recently nailed by Hurricane Gustav.......
during the hype of the storm, I think my wife's double oven took a electric surge and started smoking. I visually inspected the damage and saw a badly burnt and scarred flat saucer looking component (suppressor, transient)...I have ordered a replacement part and would like to know if you think that replacing this item will be all I will need to do..
If the range was under water I do not think this will be the only problem.
I believe it will cause you endless problems if it got submerged!
you may end up replacing this water logged unit!
Huuum
Thank You ,Please remember to leave a rating
Sep 07, 2008 | Whirlpool RBD305PD Electric Double Oven
Hurricane
Well goto the unit tag and look for the amperage that it draws when runing the generator will have to put that much current for output or more sample : air conditioner 22 amps
generator 30 amps
Sep 03, 2008 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
