Power getting to laptop but it won`t switch on
    Sergeant:
  • 264 Answers
I am giving you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it works or not.
Let me know the response as well.
Hope this should help
Regards
Sammy
Posted on Sep 03, 2008
Latop will not boot up
1.Ensure your battery is holding power. Some laptops will auto shut-off if the battery won't hold a charge. In that case, replace your battery and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
2.Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. Replace it. Note- high heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power
indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (to touch), then this is not good.
3.Check your power cord. Are there nicks or cuts? If so, unplugg it from the AC power and repair with electrical tape- better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap.
4. Check your laptop lid switch. If it is broken, you may have power but your screen may not come on.
This is usually a little button or mechanism located close to the lid hinge that turns on or off your
screen when your lid is open or closed respectively. Normally the operator does not push this button.
These are fragile and broken easily on some laptop models. Sometimes these can be fixed, more often
they will require replacements. If you aren't an expert repair person, get a technician to
repair/replace it for you. Opening up laptops is a very delicate operation and much more difficult to
repair than desktops. It may be worth it to spend the money for repair.
5. If you have tried these easy solutions and it still won't power on, then your problem lies
elswhere. You may have an internal power switch or voltage regulator problem.. Internal problems will
require professional help.
Nov 02, 2012 | Dell Inspiron 1526 Notebook
Switching off display
Most laptop displays only switch off by going to power options and setting a time for display to sleep to 10 minutes or so.
I have a big laptop with an on-off button for the monitor, but that is rare. Of course if you just think people are supposed to by psychic and know what kind of laptop you have then you won't get much help
Jul 24, 2012 | Computers & Internet
Help!!! My toshiba laptop won't turn on??
Remove the battery and unplug from power. Press the on button for 30sec then plug the power cable without the battery and switch on
May 08, 2012 | Toshiba Computers & Internet
Dell Inspiron 1501 Power Button won't turn on ....
I would remove the hinge / power button cover again and make sure the little pip that presses the button down it not broken, also check the little circuit board with the switch on to make sure it's not disconnected.
Try switching on with the cover removed.
Feb 02, 2012 | Dell Inspiron 1501 Laptop
Screen won't come on when laptop powers on
1. Software
- Try Fn + F5 or something like that
2. Electrical
- Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
3. Magnetic On/Off Switch to detect of Close/Open Lid
- Your magnet switch is fubar some how. Open up the speaker cover and see if your lid actuator switch that come in contact with the magnet on your lid cover is stuck or not (find where the magnet is in the back of the front lid cover, trace where the magnet area actually touches the base of the computer and you will find the switch)
- Workaround, start windows with lid at 30 degree angle
Toll Free: 877 407 9229
any doubts you can get in touch with the best pc doctor through
www.thebestpcdoctor.com
Oct 01, 2011 | Compaq Presario CQ60-220US PC Laptop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
