I need a universal adapter to replace part #313819876631. This item is no longer available so I'm sure there is a product that can replace this one.
  • 44 Answers
Ebay and Vance Baldwin both have substitute to that.
Posted on Dec 15, 2008
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Red light dims on Super Nintendo
I do not think on that the red power light could burn out on an SNES console but you never know.
  1. ake sure you are using a licensed AC Adapter (the system's power cord). The name "Nintendo" should be molded into the actual AC Adapter unit. If it says "for use with Nintendo" it may be an unlicensed product Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
  2. Make sure you are not using any game enhancing devices. Such devices are unlicensed and are not recommended by Nintendo, as they may not let your system function properly.
  3. Firmly plug the AC Adapter into the AC Adapter port on the back of the Control Deck and firmly plug the AC Adapter into the wall outlet.
  4. Make sure your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch (if you do, make sure the wall switch is in the ON position).
  5. Slide the Power Switch on the Control Deck to the ON position.
  6. Check to ensure that the AC Adapter is not damaged (i.e., the dog chewed the cable). If it is damaged, you may want to purchase a replacement AC Adapter.
What to do if Troubleshooting doesn't help
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product. If you simply need to order parts or accessories, you may want to check out our Online Store. Nintendo's Online Store still carries many parts and accessories for our older products.
Sep 27, 2014 | Nintendo Super NES Console
Where can i find a cassette adaptor vyms0060 replacement needed
It appears that the particular cassette adapter, VYMS0060 , is no longer available, however, if you do a web search " cassette adapters" , you'll find a whole page of sites that carry cassette adapters" The casstte adapters are universal, so they work in vitually any casstte palyer.
May 29, 2014 | Quasar VV-1302 13 in. TV/VCR Combo
PLEASE TELL ME WHAT DOES A MASTERCOOL CLEAN MACHINE PURGE PUMP DO?
From the ad below, it replaces old water with fresh. ------------------------------------------------------------------------- » HVACR» Air Conditioners» Evaporative Cooler Accessories Universal Cooler Cleaning SystemBrand: MastercoolModel: CM120ASKU: 47495 34252_300.jpg
$74.13
3 Business Day Shipping $7.91
No Longer Available Mastercool CM120A Universal Cooler Cleaning SystemTotal Ratings: 0
Average Rating: 0
Review this item transparent.gif Product Information Item Cleaning System Function Timer-actuated, Automatically Removes Mineral-laden, Dirty Water every Six Hours and Replaces with Fresh Water, Reduces Scale Deposits and Leaves Pads Cleaner, Saves Up to 70 Percentage of the Water Weight 3.10
  • Replacement Motors and Accessories
  • Universal Cooler Accessories
  • Cleaning System
  • Save up to 70% of the water used in bleed-off cleaning systems.
  • Timer-actuated drain system automatically removes mineral-laden, dirty water every six hours and replaces with fresh water.
  • Reduces scale deposits and leaves pads cleaner.
  • Uses: For residential size coolers only.
  • Note: Limited availability.
Universal Cooler Cleaning System, Clean Machine Pump Cooler Flushing Device for Residential Size Coolers Only
Apr 04, 2011 | Heating & Cooling
Sharp MD 702 Need Manual and charger or guidance on alternative\r\ncharger
Hi Boothsigns, Owners Manual available HERE Service Manual available HERE
Charger alternative: Any 5Volt DC with the same size plug of the original.
A universal power adapter LIKE THIS set at 4.5 volt will work as well. In that case, before connecting the universal power adapter to your MD 702: 1) Make sure the voltage is set to 4.5v; 2) Make sure that the polarity +/- is set properly to avoid damaging your unit!
Best of luck!
Nov 16, 2010 | Sharp Televison & Video
My remote 00053a no longer works my tv
I assume that you tried replacing with fresh batteries, the battery contacts are clean?
Universal remotes are available to replace yours. You have to type in a product code for the type of TV.
Feb 05, 2010 | Samsung TV Remote Control
Original remote for Mitsubishi CS-27EX1 tv stopped working and now after several months a replacement universal remote is unable to communicate with the tv, which works fine if the buttons below the screen...
The origional remote is no longer available. However you can get the phillips universal remote at the following link. This is one of the best universal remotes available and easiest to program and will work 3 different items. This company ships for free
http://servicemanuals.vstore.ca/
Apr 13, 2008 | Televison & Video
CHARGER
I assume by charge you mean your power adapter. If this is the case you can purchase any universal power adapter for laptops within an acceptable wattage for your laptop computer. You can either visit your local best buy or circuit city store or purchase one at newegg.com. http://www.newegg.com/Product/Product.aspx?Item=N82E16834999586&Tpk=N82E16834999586 Hope this helps. :)
Oct 05, 2007 | Gateway M305CRV Notebook
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
