Question about Neff U1721 Double circotherm Electric Oven
Hi, i have a NEFF DOUBLE OVEN U1721 and the lower fan assisted oven will not heat up, turns on as normal and fan runs BUT NO HEAT
  • Mr Stu Apr 19, 2009
    i have the same and a family friend thinks it is a new clock. But i think if the clock was not working then the fan would not turn on would it ?
  • 3 Answers
Needs new element
Posted on Sep 23, 2008
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
Lower oven not giving out any heat, fan working, light working
If fan is working ok, then you need to fit a new oven element, located at rear of oven behind a removeable cover.
Please rate my soution.
Thanks.
Nov 18, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Oct 13, 2008 | Neff U1721 Double circotherm Electric Oven
Neff fan assisted oven
sonuds like the heater is not functioning,check thermal fuse or you call repairman to asist you for speedy repair of your oven.
hope it may help,
regards
Sep 20, 2008 | Neff U1721 Double circotherm Electric Oven
Neff u1721 fan door problem
yes it is a heat resistant adhesive and ive never had any success in regluing them
Nov 06, 2007 | Neff U1721 Double circotherm Electric Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
410 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
