Question about Dell Inspiron 1200 Notebook
I did that already the test reaD 150 - Dell Inspiron 1200 Notebook
  • Dell Master
  • 13,433 Answers
Can you tell me what kind of internet service you have currently
Posted on Sep 04, 2008
Fix a system monitors" not ready" reading during emmissions test
Hi Paul@ FIREFOX,
The most common cause is the engine is not upto working temp.failing this you will need to use an O.B.D 2 meter to pin point fault this will flag up a fault code it works out alot cheaper than changing parts to cure the fault hope this helps....
Oct 03, 2014 | 2008 Ford F-150
Stalling
is your engine light on if code reads lean fuel , probaly O2 sensor
Jan 11, 2014 | 2005 Ford F-150
What compression for 2001 chevy s10,2.2
Car is 12 years old, average mileage for that is well over 100K, so expect compression somewhere between 150-200 psi. Important that readings are still close together for balance, but you have some leeway there: Most manufacturers say lowest compression should be within 80 % of highest reading. Any cylinder with low compression (below 140 or 150) should have a leak-down test to pinpoint where compression is lost.
Mar 22, 2013 | Chevrolet S 10 Cars & Trucks
Saturn Vue base model 4cyl. 2.2 failed Emission test
probly need a new catylytic converter--dont buy aftermarket get original--also inspect air injection and all other emission control devices
Apr 21, 2012 | Cars & Trucks
I have a 1991 Dodge Ram 150 V8. I have replaced the battery and alternator and the battery still going down.
you need to test the alternator output in the car with the engine running it should read around 14.2 vdc. if the out put is lower the voltage regulator is part of the engine control computer. and will need to be tested. if the voltage is correct. then you will need to do a battery draw test hear is a viedo on that.
May 06, 2011 | 1991 Dodge Ram 150
I have a 1998 f-150, it has 140,000 miles on it. i jst had new spark plugs changed and fuel injectors put in it. and it quit shakin 4 a couple days but then it started to shake again. can anyone help?
have your battery tested already?? it must be 12 vdc + reading at idle and appx 14 vdc + when steppping on the gas pedal is the reading on the meter (set to 15vdc or higher) also try new distributor cap which might be wet or rusty. or even sparkplugs cables might be rusty.
Jan 13, 2011 | 1998 Ford F150 Regular Cab
I own a 95 F 150 and my instrument panel lights don't come on
Dash light could be your dimmer switch. as for your tail light check power at chasis junktion plug with test lght 4 buck at wal-art. ford used fuseable links as a safety feature in case of shorts but you cant see when they blow so test light is your friend.
Sep 26, 2009 | 1995 Ford F150 Styleside Regular Cab
DISC READ ERROR?
THE LENS IS DAMAGE ALREADY I HAVE THE THE MACHANISIM FOR WE COULD REPAIR IT FOR $150
Mar 29, 2009 | Kenwood KVT-715DVD Car DVD Player
Where are the cigarette lighter fuses located in the fuse box?
read the fuse schematic. If you have a 12 volt test light you can test a fuse
Mar 26, 2009 | 2007 Ford E-150 XLT Wagon
Dell Inspiron 1200 Notebook Logo
23 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
