Question about Toshiba Satellite 2060CDS Notebook
Lost my operating system?
When it powers on I get
Boot 1>error
cannot run system commander
missing syscmndr.sys.
    Scholar:
  • 81 Answers
You have lost your operating system, and you need to reformat your hard drive and do a clean install of your operating system. This has happened to me, and This is what you need to do.
Posted on Sep 04, 2008
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Aug 17, 2014 | Computers & Internet
Disk error
Use operating system disk and run the command: chkdsk /r
This will run for an hour or more but it will repair any boot and system files that are corrupt or missing.
Mar 10, 2012 | Toshiba Tecra 8200 Notebook
My computer says: DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. What should i do?
well one or two things has happen eather your operating sys crashed wich will have to be reloaded or make sure you dont have a cd rom in the cd tray cause if it is a bootable cd it will cause the same error message chances are though you need to have windows reinstalled
Jan 27, 2011 | ASUS Computers & Internet
Hi all, I have been desperately searching for a solution on the net all day. My Dell Inspiron 1420 on Vista platform will not boot up as a result of accidentally switching off the power. Have tried the F8...
This will fix it.
1. RUN DISK DEFRAGMENT FROM WITHIN YOUR OPERATING SYSTEM OR DURING STARTUP 2. RUN FISK DISK COMMAND FROM MS DOS 3. RUN CHKDSK COMMAND FROM MS DOS 4. IF YOU CONTINUE TO EXPERIENCE PROBLEMS, PLEASE RETURN FOR MORE DIRECT HELP FROM ME.
Jan 22, 2011 | Dell Computers & Internet
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
What would make an hp laptop w/windows vista not turn on ,even tho its fully charged
So many things. Does it turn on at all or it just won't boot into Windows? If it doesn't turn on at all, remove the battery and run straight from the power cord. Make sure you are getting power to the computer.If you are getting power and the system turns on, but won't boot into Windows, trying booting into safe mode or using a recovery disk to start at a command shell. Remove the hiberfil.sys file and try to restart. The hiberfil.sys is a hidden system file so you'll need to use the following commands;
attrib -r -s -a -h hiberfil.sys
del hiberfil.sys
Try that. I just fixed a laptop last week and I had to delete the hibernation file in order to get the laptop to boot.
Nov 21, 2010 | HP Computers & Internet
In My PC Error Shows NTDLR File Is Missing,How To
Method:1
1.Make the first boot device as CD-ROM
2.Boot the system with windows(operating system cd)
3.go the first repair(r) option
4.once u got the command prompt change you directory to X:/i386
copy x;/i386/ntldr c:
copy x:/i386/ntdetect.com c:
note:x:(cdrom) drive may change
and then reboot the system.
method 2;
boot with the operating cd and go the second repair option and repair the operating system
Dec 02, 2009 | Gateway 500GR PC Desktop
I am having trouble running setup on my desktop
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
Aug 28, 2009 | Computers & Internet
Problem with command enterpreter
Do you mean that you are receiving a message about the system wanting to know where the command interpreter is when you try to boot?
The command interpreter is called command.com and it should be in the root of your C drive. The full path to it would then be c:\command.com and if it is missing you will not be able to boot.
If this is your problem, hopefully you have a win98 boot floppy. If you do, put it in, boot up, when it gives you an A:\ prompt type:
sys c:
and when the command completes and you are back to the A:\ prompt, the problem should be resolved. At that point, remove the floppy and reboot the computer.
If this doesn't take care of it leave a comment and give me as much info as you can. We'll get you running.
Apr 25, 2009 | Microsoft Windows 98 for PC
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Toshiba Satellite 2060CDS Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
