Question about Toshiba PDR-M81 Digital Camera
Manual focus How do I control the Manual Focus?
    Novelist:
    Scholar:
  • 104 Answers
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button. 2) Press and Hold the DISP/i button to see the Manual Focus Range. 3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key. 4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture. *Press the Focus Button to return to Auto Focus / Macro options
Posted on Sep 15, 2005
Polaroid 690 SLR-The switch between manual focus and auto focus, does not appear to operate normally. Maybe I do not know how to use it, however I cannot manual focus. Are you familiar with this camera and...
Not sure if this will help, but according to the manual, to use manual focus, push the button down until the red portion is visible, and turn the manual focus control dial until the image appears in focus in the viewfinder. Then, take the photo as normal. To return to autofocus, just return the switch to its normal position.
Sep 15, 2011 | Polaroid 690 SLR Instant Camera
All the pictures are blurry the auto focus isn't working
You may have put the camera on manual focus. Two ways to do that.
1. There is a switch on the lens which allows you to select auto or manual focus. Be sure the switch is set on A or A/M. If it's on M, you are on manual focus.
2. In you menus, there might be a mode which is manual focus. Look in your manual index under Focus, manual. There might be a setting in the Focus Mode menu.
You can also try resetting your camera. This will put most things back to factory default mode, including the focus mode.
When playing around with controls, go step by step through the manual and try things out. Be sure to set the control you were playing with back to default unless you really understand that setting.
Apr 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Is it possible to manually control the shutter speed, aperture, AND the focus on the Konica Minolta Maxxum 400si SLR 35mm film camera? I need to be able to manually control these features for a film class...
Yes. You have full control over the shutter speed and aperture in the Manual exposure mode, as described in the "M Mode: Manual Exposure" section in the manual.
You also have full control over the focus, as described in the "Manual Focus" section in the manual.
If you need a manual, you can download it (in two parts) from
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Feb 07, 2011 | Minolta Maxxum 400si 35mm SLR Camera
Is it possible to manually control the focus on this camera? (Konica Minolta Maxxum 400si SLR 35mm Film Camera) I need to be able to manually control the focus, apeture, and shutter speed for a film...
The description of the manual focus is available in part 2 of the manual, page 40. The manual is available as a PDF here: http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html#si_series . It is the seventh camera in the SI series in the list.
To manually focus the lens, press the focus-mode button on the front of the camera (bottom left when you are behind the camera) until M. focus appears in the data panel. If you have an AF lens, turn the focusing ring until the subject appears sharp. If you have an xi-Series or AF Power Zoom lens, pull and turn the lens control ring.
The focus indicator will light when the subject is in focus. To return to autofocus mode, press the focus-mode button again. The camera will also return to the autofocus mode if you press the program reset button.
I hope this helps.
(in manual focus, you can take a picture even if the subject in the focus frame is not in focus. Often it means you need to take multiple pictures to get a good shot of the subject. The advantage is that you can get some interesting shots.)
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
The manual focus ring on my camera doesn't work. The ring turns but does not seem to adjust the focus. Automated focusing still works. How to fix it?
Two methods:-
1. Use the slider switch on the left of the camera to set it to MF (manual focus). The focus ring is an electronic one rather than a physical control like the zoom ring, so the response can seem slow.
2 Go into the camera menu and enable DMF (Direct Manual Focus). This allows you to override the autofocus simply by adjusting the focus control, but it does not work if the slider switch is set to the AF C setting (continuous autofocus), it only work in the AF-S (AF only activates once when the shutter is half pressed).
Jan 31, 2011 | Konica Minolta DiMAGE A2 Digital Camera
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Ag-dvx102a can,t focus manual
you can't manual focus if you have a remote control hooked up to the focus/iris port on the camera, you will only be able to use the remote. Otherwise, try turning off Auto Focus.
Jun 20, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
Manual Focus
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Can I manually control the zoom and focus?
Yes. Zoom can be controlled either by a variable speed rocker control, or a zoom ring on the lens. Focus is either automatic or manual via a focus ring.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Toshiba PDR-M81 Digital Camera Logo
229 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
