Question about HP Color LaserJet 2600n Printer
Double images from printer
My HP Laserjet COlor 1600 is giving me double images (makes you feel drunk) some of the time...not all of the time. Any ideas?
  • 300 Answers
This is normally caused by a defective toner cartridge
Posted on Sep 03, 2008
  • wayne churchill Sep 03, 2008
    Sorry i misread your problem this is most likely to be caused by the transfer belt unless this only happen on single colour prints ie mono which could indicate a defective cartridge. The easiest way to check is to stop the printer half way through a print by opening the front door, then check the image on the cartridges and the transfer belt. You will need to try this a few times to get the timing right.
Can I make convert my HP laserjet 3800n into a 3800dn so i could print double sided automaticaly ?
You will need to buy a 'hp color laserjet auto duplex unit' to effectively turn your 3800n to a 3800dn and change the printer onboard controller but cost would probably more than buying a newer model with automatic double side printing support ... It is technically possible but I would not recommend it.
Sep 24, 2011 | HP LaserJet 3800n Printer
Sir thanks for your hp 2600n printer suggestion but still problem is not solved blur image and prints double image
You can read about how to solve print quality problems for this printer on this page.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826#A6
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 12, 2011 | HP Color LaserJet 2600n Printer
Prints double image -- everything printed has a double image. Looks like a ghosted image and is offset to the actaul page.
http://www.fixyourownprinter.com/forums/laser/42756
Hi this link above directly addresses your issue with a view to a fix.
Below is how to troubleshoot your issue, it seems it can be a few things.
Below is your service and repair manual, that will have what to do. www.partshere.com/.../CLJ1600%20removal_replacement.pdf - United States http://www.streetdirectory.com/travel_guide/118490/printers/solving_image_problems_on_hp_laser_printers.html
Jun 06, 2010 | HP LaserJet 1600 Printer
My hp color laserjet 1600 ''incorrect yellow''
did you use a genuine toner cart.........!!!!
Mar 30, 2010 | HP LaserJet 1600 Printer
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Nov 24, 2008 | HP LaserJet 1600 Printer
Double image
change color toner with original Hp tonars
Mar 16, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
903 people viewed this question
Seeker5211
Seeker5211
