Question about Samsung SMH7178STD Microwave Oven
Turbo vent won't turn off
My turbo vent automatically came on when the oven wasn't very hot and will not turn off. Even after unplugging and leaving the door open to reset once I plug it back in (up to days later) the vent starts going and I am unable to use the microwave
  • Samsung Master
  • 9,098 Answers
This is usually caused by a shorted hood thermostat or a shorted triac on the control panel circuit board.
The hood thermostat is usually located on the floor of the microwave chassis behind the control panel. It should read "open" or "infinity" on a continuity or multimeter resistance test.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
If the hood thermostat is bad, You can order Samsung parts here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 06, 2008
My Panasonic 1300w microwave will not turn off. It doesn't cook but won't turn off without actually unplugging it or opening the door and leaving it open. Any help?
You may have a shorted door switch or a shorted relay on the control board.
You can see a help file on door switches here.
Dec 01, 2012 | Panasonic NN-SN657SMicrowave Oven
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
GE Spacemaker Microwave Oven - need to replace auto vent door
IF YOU KNOW NOTHING OF ELECTRICS ESPECIALY M/WAVES LEAVE WELL ALONE THET CAN BE ===LEATHAL===I MEAN LEATHAL.
Oct 04, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R305KS Stainless Steel 1100 Watts Microwave Oven problems:1.5 years old. We put in a microwave popcorn bag and had bright flashes going off as though there was metal left in there and gurgling...it...
unplug microwave.
Take ALL dishes out of the microwave and do a proper check of the inside the cooking area. If you are sure that's ok put the glass dish back in if it has one.
Test that the oven and grill are still functional.?
Do they heat up? If they do then get one of those microwaveable bowls or dishes and put some water into it. Place it back into the microwave and do the check again on microwave heating.
Does it bang or spark again?
If it does and the other heating is OK then the Magnatron to me sounds as it's on it's last legs.
That does not mean you have to scrap the microwave if it is the Magnatron. as a new one can be purchased and installed.
Apr 12, 2017 | Sharp R305KS Microwave Oven
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
Jan 01, 2011 | Samsung Microwave Ovens
Microwave vent turned on by itself and won't turn off
The HMV9305 has an automatic vent turn-on feature. It senses heat, possibly from the oven or range beneath, and turns on the exhaust fan until temps return to normal. Sometimes this may take 4-5 minutes, which can seem like an eternity of listening to the blower run, but it is a safety feature designed to prevent damage to the microwave from excessive heat generated by the cooktop or oven beneath it.
Jan 24, 2010 | Bosch HMV9305 Microwave Oven
The fan will not stop running,says locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it's still running, is it the hood vent exhaust fan (which you can normally turn on and off manually) or the internal cooling fan (which normally comes on automatically whenever you microwave)?
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/t2929351-fan_will_not_stop_running_says_locked
William E. Miller
prototech@usa.net
Sep 12, 2009 | Whirlpool Microwave Ovens
Fan does not shut off unless unplugged
If the light and fan come on when the door is opened normally, check the door switches.
May 19, 2017 | Kenmore 80809 Microwave Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
I have an LG LMVH1750ST microwave convection oven. When I activate the fan for cooking purposes and then try to turn off, it does not respond. I have to pull electrical plug and reprogram for one minute....
From the owner's manual under OPERATION "VENT FAN":
"If the temperature from the range or cooktop below the oven gets too hot, the vent fan in the vent hood will automatically turn on at the 4-Speed setting to protect the oven. When this occurs, the VENT ON/OFF pad will not turn the fan off."
You should check your "vent fan auto time set" setting.
Here's one thing to try to set it to turn off after 10 minutes:
Touch the Vent ON/OFF pad, then touch the "5-SPEED VENT" pad until "level 4" appears in the display, then touch "AUTO TIME SET" the desired number of times.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | LG Microwave Ovens
Microwave Ovens Logo
129 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
