Question about DeLonghi Pinguino PAC-600T Air Conditioner
Our system senses when to turn off to cool the room, but does not sense when to turn off
Our system recognizes when the room gets too hot (within a couple of degrees) and it starts to cool our baby's room, however it doesn't sense when to shut OFF the air conditioner and it gets way too cold in her room.....do you think we have something wrong with the settings? We have it on AUTO - the other options instead of AUTO are Max, Min please HELP this is difficult trying to climate control her room for healthy sleeping. Thank YOU.
Lynn
  • 236 Answers
Try to set the thermostat or temperature to higher setting.
Posted on Sep 25, 2008
Where is cpf12xhl temp sensor?
May be your sensor fell down. please insert with plastic clip and the clip to fixed in the middle of the coil.
May 01, 2014 | Haier Heating & Cooling
Tip
Too cool or over cool in room
Indoor sensor to sense the room temp and must cut off the compressor by working. If sensor defective, compressor will continuously running resulting to over cool in room. And also 23 C degree setting temp is best cooling for office and bed rooms. If for peculiar instrument which should be kept under low temp, can be set as mentioned temp (say 18 C or 16 C )<br />
on Jan 10, 2011 | Heating & Cooling
Dyson hot and cold fan only works in hot mode
Hi there, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 09, 2012 | Dyson AM04 Hot Cool Fan Heater White
I'm getting E2 error code on my Voltas 1.5T window AC? can u pls help
Comonly that is because the condenser sense is not conected or faulty, but check also the room temp sense as the solder in the conector in the main board. (condenser sense is metal case, and room sense is plastic cover).
Sep 10, 2011 | Heating & Cooling
Unit will not heat, change batteries controller cleaned filters etc. Still blowing COLD air
Check the thermostat setting...in the auto machines, with a reversing valve, there is no heating or cooling, generally, in the sensing temperature band of 19 Deg C to 22 Deg C and it only works on blower mode, re-circulating the room air. When the sensing temperature goes below 17 deg C, it works on heating and when the sensing temperature goes above 24 deg C, it works on cooling
Sep 05, 2011 | Heating & Cooling
When tv is turned on message comes up that tv will shut off....check for dust etc. Room is cool. Tried system reset. removed and reset bulb in place. Any ideas? Barry
Cool room will not have much effect on the inside temperature of the TV. Check for the dust on the air filters of the projector & clean them. Inside the projection TV there is thermal sensor which senses the temperature. If it is more than the maximum recommended temperature set by the manufacturer, it shows the above message. It is quite likely that your TV's thermal sensor is not functioning or a fault has occurred in the sensing circuit.
-sonsunny
Jul 24, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Home theater keeps shutting off. Display reads chkfan just before shutting down.
It's either very hot (temperature sensing) or it knows the fan is dead (fan-motion sensing). Have you checked it for being too hot, looked at the fan and made sure the unit has plenty of clearance around it for cooling airflow?
Jun 09, 2010 | Audio Players & Recorders
Dh305y6 keeps shutting of within minutes
sounds like you need to replace your humidistat control. this is just like a thermostat on an air conditioning system, except inside of sensing temp and turning off, it senses humidity and turns off.
Jul 02, 2009 | Goldstar DH504EL Dehumidifier
I have a vitodens 100-w combi boiler and tried to turn the heating on just to give it a working as was advised. However, I have no heat coming to my radiators. The boilers seems to be working as my hot...
Here's the deal: If your Vitodens 100 has outdoor temperature sensing capability, either built in or via external aftermarket control such as Tekmar or other, and the temperature outside is above warm weather shut down (WWSD), then the boiler will not operate for space heating, but will operate to make Domestic Hot Water (DHW) only. Generally speaking WWSD is facoty set at 20*C, since this is normal room temperature so the boiler will not need to operate at temperatures above this number as it is warm enough outdoors to heat the house to comfortable levels.
If your Vitodens 100 does not have outdoor temperature sensing capability then you should check to see if your room thermostats are operational and calling for heat since the boiler is only responding to this on-off control based on room temperature. (turn up your room thermostats)
In both cases you need to make sure that your heating system's distribution pump and zone valves are operating correctly.
In any case you should be calling a heating contractor if you suspect that there is a problem with your boiler and/or heating system.
Good luck.
Aug 07, 2008 | Heating & Cooling
Cooling on and off
Behind the filter there should be a small metal tube that senses the temp. entering the unit sometime this is too close to the metal fins and sense the cold from the fins and not the air coming in. Make sure this is away from the fins and try a different temp. setting.And relocating the unit. These units tend to give off more heat that cooling because the hot air is returned to the inside of the room and not vented outside like window units.This is an  EdgeStar 12,000 BTU unit, correct?
Oct 22, 2007 | EdgeStar Portable Air Conditioner Heater
DeLonghi Pinguino PAC-600T Air Conditioner Logo
275 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
