Question about Toshiba PDR-M81 Digital Camera
Getting accurate color
How can I get accurate color?
    Novelist:
    Scholar:
  • 104 Answers
1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Posted on Sep 15, 2005
How do I print artwork getting all the colors to render accurately, so that it looks like the original painting.
Unfortunately you screen (computer or other ) isn't calibrated.
there is software mostly pro use this, but take a picture of a flat grey placard.
using your photo program to check the gamma settings and modify them until the grey on screen matches placard ( hold placard next to monitor). Then print out grey image.
important write down the gamma settings and when you put something to print check to see if these are close.
Sep 26, 2016 | HP Designjet Z6100 InkJet Printer
Brother HL-4040CDN printer colors are off, tend to be pink
There could be a number of causes for the problems your describing, but one of the most common causes of discoloration and issues with toner is a faulty ribbon sensor. A broken sensor will be unable to accurately read the ribbon and apply the correct color. I hope this helps
Sep 02, 2012 | Brother HL-4040cdn Color Laser Printer...
Scanning is not producing accurate colors for all colors. For example, Halloween shade of orange scans as pure yellow and brown comes out quite pink. Tried shutting the machine down and restarting much...
You'll need to calibrate your printer in order for the prints to come out with the correct color. In addition to this, if you're printing from .pdfs, you can set Acrobat to "print as image", this also helps in correcting the colors as they appear on your monitor, although this is NOT as accurate in correcting color as the "calibration" part.
Hope this helps. :)
Oct 06, 2010 | Canon PIXMA MP520 InkJet Printer
Color is not accurate
If the color quality is out of adjustment you can refer to your user manual (available form the web interface of the copier machine) and it will tell you how to adjust the color (slightly). If your colors are way out of scope then you will need a qualified copier technician to calibrate your copier back to factory specs.
Sep 24, 2009 | Sharp MX-2300N Color Copier
How do I check the trans fluid in my torrent 2006
Their are two dipsticks under the hood one is motor oil it is brown in color. The transmission will be a little closer to the fire wall it will be red in color. Your car needs to be running to check trans fluid for an accurate reading. With motor oil your engine needs to be off for an accurate reading
Sep 06, 2009 | 2006 Pontiac Torrent
Hi: My acer56c is eight years old and humms while turned on as well as getting the horizontally linear blue occasional flash across screen.The colors when turned on are not 'initially' accurate(Orange...
if its a CRT monitor then you wont have a problem, the all get decrepid and loose color flicker then eventualy die.
i say use it till it dies then get a new one or get a new one befor it dose damage to your eyes, a nice TFT screen will do.
Jul 03, 2009 | AcerView 56C (White) 15 in.CRT...
Printout getting fainter magicolor 2300dl
Probably low toner if fading is on black only or a single color. To check levels, MENU (right arrow to Consumable Usage) MENU (right arrow to see each toner cartridge level) Readout may not be accurate, especially if you have changed or removed a toner cartridge.
Dec 10, 2008 | Konica Minolta magicolor 2300DL Laser...
A205 problem
You are getting too much (light) over-exposure.
If you have an option in the cameras menu to lower the shutter speed (smaller Fraction) or using a smaller (larger number) aperature, this will help get a more accurate exposure.
~ycsphoto~
May 11, 2008 | Fuji FinePix A205 Digital Camera
Accurate color
Digital cameras rely on "white balance" to control total overall color accuracy as processed for the final image. Colors are greatly affected by light. For example, look at any wall in your home or office and you can easily see that shadows will make the color of the wall appear to be different shades. Sunlight has a very different effect on colors than incandescent light or florescent lights. Digital cameras start with white (the absence of color) to measure the effect of light and adjust the metering (measurement and accuracy) of all the other colors. Of course, white in a poorly lit room may appear gray or even yellow to some digital cameras. So how can you get accurate color? 1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Toshiba PDR-M81 Digital Camera Logo
83 people viewed this question
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
