Question about Yamaha Dtxpress Iv Special Electronic Drum Set
DTXPlorer The LCD display's.....WARNING, Battery Low The system was bought in late 2005 spedbird@bellsouth.net
You can replace the battery yourself in about 20 minutes. It is not soldered. You will need a replacement battery, which is a CR2032 watch battery, a small Philips screwdriver, and needle or thin-nosed pliers.
1. Remove all cables from the dtxplorer unit, and remove it from the drum kit rack.
2. Remove all 6 screws from the bottom side (i.e. opposite the face)
3. Remove the 3 lowest screws from the rear (jack-filled) side, including the one which holds in the little plastic power cord hook, then lift off the bottom and set aside.
4. You will see the bottom circuit board, covering the top board. Carefully pull off the spade connectors from the power switch, using pliers or patient wiggling, they are on fairly tight but will come loose. Note which one is which for proper reattachment.
5. Near the center of the board is a little white plastic post end sticking up, through a hole, from the inside (top) board, with small tabs. This loosely attaches the two boards. Using small pliers, squeeze the tabs on the post end, and pull up on the board and it will separate from the inside (top) board. Carefully move the board toward the front of the unit to free the jacks from the holes in the case, and then you can easily fold the board toward the front, like opening a book. (Don't try and remove the large wire sets attaching the two boards)
6. You will see the button-like battery. Just push it toward the spring clips at one side and lift it out. Replace it with the new battery, + side out.
7. Just reverse the steps to reassemble, hook it up and you're ready to go. Easier to do than this makes it seem. Greg
Posted on Jun 11, 2009
  • 1 more comment
  • geeeeeza Dec 13, 2010
    CARE Re item 4,
    instead of pulling spadev connectors from switch, go to other end of wires and pull from the white plastic fitting on board. (i recomend this, as i pulled the spade connector out of the back of the switch. Am now looking for a new switch).
  • djsp8 Feb 09, 2011
    Just successfully completed this job as per Solution 4. No problems...Thanks
  • Fabrice Dcrau
    Fabrice Dcrau Jun 23, 2017
    WARNING About item 4: don't pull out the 2 black cables from the power switch, you won't be able to put them back in. Instead, cut the small plastic thing that attach the cables to the board, and you will be able to detach the board enough so you can reach to the other end of the power cables : a white plug that you can gently unplug (and plug back in).
****attention** **the screw that holds the midi out connector has to be removed before board will come out .just thought i,d ad this in case there are others that are rammy like myself.this site helped big time .thanks . Matt
Posted on Jun 27, 2010
    New Friend:
Its very easy easy u can do it ur self... i would suggest discharge ur hands as well b4 touching any PCB/s .. ya pull out the plastic connector , its easier that the switch connector .. simple.. replace the battery + up.. thats all. sam
Posted on Jan 05, 2013
Hi - I've posted a youtube video showing how to replace the battery in the DTXplorer.
http://www.youtube.com/watch?v=D46e-CAD0ek
Posted on Aug 03, 2011
  • mgb250753
    mgb250753 Aug 22, 2012
    Very helpful I feel confident i can do it myself now Thanks Dr bob
Addition To Solution #3: I had a very hard time removing the spade clips from the On/Off switch. I only got the top one off and decided to cut the tie wrap that holds the wire to the circuit board. After squeezing the white tabs on the connector post that holds the circuit boards together, I was then able to pull the the circuit boards apart far enough to expose the On/Off connection to the circuit board. Just follow the wires. This small white plastic connector came off very easily. The hardest part of the job was removing and replacing the screws!
Posted on Oct 30, 2010
  • 1,879 Answers
Battery Notice:
This product MAY contain a small non-rechargeable battery which (if applicable) is
soldered in place. The average life span of this type of battery is approximately five
years. When replacement becomes necessary, contact a qualified service representative
to perform the replacement.
Posted on Sep 03, 2008
    New Friend:
  • 3 Answers
Ive replaced mine with the proper battery cr2032. And the screen still desplays warning low battery!! Anyone else have this problem? And is ths fixable?
Posted on Nov 08, 2014
Yamaha dtxplorer!!!! I replaced the battery and still have a warning low battery notice on the screen. Anyone else had this problem?
If the new battery tests good on a voltmeter ( you'd be surprised how often they don't) I would suspect that the battery holder's contacts need to be cleaned.
Nov 08, 2014 | Music
When I turn on my Kurzweil PC2X, the LCD screen shows the message 'Scanner is dead!' followed by 'battery voltage low (0.0 volts).' The lights on the keyboard flash at me and the keyboard won't make any...
Try a factory reset.
Turn the unit on, and while the display says "Please Wait", press and release the Panic button. Press the right arrow button till the display says "Hard RESET". Press Enter, then the button under "Yes" in the display.
Sep 03, 2012 | Music
Drum kit won't power up
Get a voltmeter and check the power to see if it is working at the plug. the voltage should be 12vdc. If you don't have a meter, just take the power adaptor to radio shack, or any electronics supply house.
They'll check it for you. below is a copy of the manual. Good Luck!
Download Yamaha DTXPLORER User manual
Sep 01, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
Is a dtxplorer bought in the USA set for 110 volts and therefore do you need to get a converter to use it in a 220/240 volt country?
Yes, the adapter takes 120 volts... Best way might be to get a 220 to 110 trnasformer converter then you can run other stuff as well... Get one of the step down transformers in first column... the 100 watt one would be more than adequate, but for future things you might want higher rating.
http://www.world-import.com/transformers.htm
Apr 06, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Mar 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
I just bought the DTXplorer e-kit, and have set it up perfectly, but get no sound from hitting anything.
Test the amplifier with another sound source to make sure the amp is good. Use a guitar or anything to test.
Dec 18, 2010 | Yamaha DTXplorer 5 Electronic Drum Set
Bought a new electronic drum set, Yahama DTXPLORER, cannot get sound
Double check and make sure all the chords are plugged into the control box for your set. Most electronic drum sets require the use of headphones or some sort of PA system to hear whats being played. If you could expand a bit on the description of your problem, I should be able to help more.
Dec 25, 2008 | Music
Dtxplorer volume knob problems
No one "glues" knobs on except inapt consumers. Make sure there is not a "set screw" in the side of it. If not, it just pulls off.
Oct 08, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
2,454 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
