Question about Toshiba PDR-M25 Digital Camera
Set Resolution
How do I set the Resolution on my camera?
    Novelist:
    Scholar:
  • 104 Answers
Use the resolution button on the top of the camera by the LCD display. One button is for selecting Flash. One button is for the self-timer. The middle button is for resolution. Press the button repeatedly to cycle through the options.
Posted on Sep 15, 2005
How to set for 300 dpi
The dpi is not really a camera setting. The camera should usually be set to the highest resolution possible (4000x3000). This capture size would give a print size of approx 13"x10" at 300dpi. That would be considered a high resolution print. If you were printing at "normal" print resolution you could double that print size.
May 20, 2014 | Pentax Optio W80 Digital Camera
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
No date stamp on photos on Canon XTi camera
Most Canons don't seem to be able to embed the date on photos unless the resolution is set to "postcard mode", which is 1600 by something pixels. Set to that resolution, and then try to set the date mark feature (it will be greyed out when the resolution is not set to a compatible mode).
Jan 09, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
In uploading to a website, so that pictures could be printed, a comment states low resolution and the pictures may be blurry when printed. Is there any setting on the camera that I can change that would...
I dont know what resolution your camera is, but make sure you have it set at the highest it can go. The higher the resolution the better quality the picture. I had a 12mp camera but you could set it as low as 4mp which is ok for snaps but if you are uploading or printing then you need to set your camera to a higher resolution if you can. Read your instruction book it should tell you how to configure your settings there. If it is an old camera that cant be changed then maybe its time to invest in a higher mp camera perhaps 8mp 10mp or even 12mp
Oct 04, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
How to set picture resolution.
Turn the camera on and set the slide on the right hand side to the red camera icon, as if you are taking photos. Turn the dial on top of the camera to the red camera icon. Press the middle circle button (menu/set), you will see that the 'picture size' menu is highlighted. Press the right arrow key to view the different resolutions available, select with the up, down and menu/set button. Press the menu/set button again to leave menu. To change resolution in intelligent auto mode, do the same thing but turn the dial to the red camera with the 'iA' in it.
Sep 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
Enlarging file size of pictures
That camera shoots at 7.2Megapixels at max resolution, that should print an 8.5x11 without any issue.
Check the settings on the camera to make sure that you've got it set to take "high" resolution, and not "low".
In the settings, there should be a resolution option that you can change. It's likely set to take lower resolution that what the camera can actually handle.
Mar 19, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Resolution is low!
Easiest was is go to Camera Menu -> Initialize -> Yes.
Camera will reset and select factory default settings.
Other way is set camera on camera-mode, press menu and find picture resolution setup, you will see fine, standard, vga, email options there, select desired option and done.
Jan 18, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
I want to set the resolution of my digital camera. How do i do it?
Not all digital cameras operate the same for resolution settings.
It's almost always done within the menu under settings. If you have the manual, look in the back index under "resolution". Otherwise just access the menu and scroll through it, you most likely will find the resolution setting item.
Nov 04, 2008 | Cameras
Setting resolution on s5000 digital camera
It did likely re-set to lower resolution when the batteries were changed. To set it where you want, press the "F" button when in shooting mode. You'll see the options, one of which is for image size/quality.
Oct 06, 2008 | Fuji FinePix S5000 Digital Camera
Resolution
To set the resolution just Press the MENU icon (middle icon) on the left side of the LCD screen. Then press the QUALITY icon (lower row left icon). Choose from one of the four icons.
Sep 11, 2005 | Toshiba Sora PDR-T30 Digital Camera
Toshiba PDR-M25 Digital Camera Logo
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
