Question about Generic Memory Compaq Presario SR1215CL by HP AMD Sempron 3000+ 512MB 120GB CDRW/DVD w/XP [Refurb] [MIN90] PJ506AA... (PJ506AAR) PC Desktop
Presario.Message says memory full.Nothing opens up
Complete novice with computers
Had this 2 yrs.nothing done with it
How -in short term-can I resolve this problem .Short of a trip to a computer shop
Isnt there something called defragging or something???
All help appreciated
Dr David Noble
    President:
  • 2,961 Answers
Yes defragging is found on the accesories menu in system tools, but your cache memory is full because of all the programmes taking up the memory, you need to install more memory.
Run this tool to tell you whats fitted and what type to buy, it's very easy to fit more memory and will speed up your system also, it's cheap, and if you take it to a shop to fit they will charge around £15.00/$30.00 to fit it when it's easily done, take the side off and look for the memory strip and there will probably be a spare socket to fit another one or remove current memory and replace with a larger amount
Posted on Sep 03, 2008
Free online sentence rephrasing
The present study investigates how working memory and fluid intelligence are related in
young children and how these links develop over time. The major aim is to determine which
aspect of the working memory system-short-term storage or cognitive control-drives the
relationship with fluid intelligence. A sample of 119 children was followed from kindergarten
to second grade and completed multiple assessments of working memory, short-term memory,
and fluid intelligence. The data showed that working memory, short-term memory, and fluid
intelligence were highly related but separate constructs in young children. The results further
showed that when the common variance between working memory and short-term memory
was controlled, the residual working memory factor manifested significant links with fluid
intelligence whereas the residual short-term memory factor did not. These findings suggest
that in young children cognitive control mechanisms rather than the storage component of
working memory span tasks are the source of their link with fluid intelligence.
Apr 20, 2013 | RE-phrase RePhrase Trip Italian
Screen wont turn on. try to start the laptop and it beeps three times one long then two short. then nothing just stays black.
Reseat your memory.Your memory fail during POST. Open the back compartment with 2 screws holding it and you should be able to get to the memory.
Usually reseating the memory will resolve if not replace them.
Dec 31, 2010 | HP Pavilion dv6000z Notebook
3 short beeps.
This indicates a memory problem
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Sep 14, 2009 | EliteGroup K7VMM Motherboard
Gateway CX2600 does not turn on
may be its lustred try to borrow another charger like your charger and if nothing happen buy new charger In spam the anti virus in your computer is always updated and if not always updated may harm your files and is not term in your charger
Aug 07, 2009 | Gateway Convertible CX2620 Notebook
Hp a1420n problem copying photo to disc
compaq presario sg1118il drivers i want
Mar 17, 2009 | HP Computers & Internet
Compaq presario v2405us can't boot up
I did not get if the keys are working. If not, check the keyboard ribbon. It might be out of place.
Else, it might be the hdd.
Oct 18, 2008 | HP Compaq Presario V2405us PC Notebook
Trouble starting up computer
First thing to do is remove as much as you can from the motherboard, cdrom,some memory(if possible) floppy drives ect...
any slot cards then try it and plug each item in and reboot each time till you find whats causing it. or could be a week power supply
Feb 26, 2008 | E-Machines eMachines Desktop PC
Dell optiplex Gx 150
This is a problem with your memory.
During POST, the computer checks the computer's memory, determines the amount of installed memory, and then writes to and reads from the number of available bytes to ensure proper operation.
Basic Checks:
  • If an insufficient memory message appears, save and close any open files and exit any open application programs not in use.
  • Consider installing additional system memory.
  • Run the System Memory test in the Dell Diagnostics.
  • Reseat the memory modules.
  • Restart the computer.
If the problem still exists after you complete the basic checks, fill out the Diagnostic Checklist as you perform the following steps.
caution.gif CAUTION: Before you perform this procedure, see "Safety Information."
  1. Reboot the computer.
Does the RAM count displayed correctly match the actual amount of memory installed in the computer?
Yes. The computer needed to update the memory count. The problem is resolved.
No. Go to step 2.
  1. Run the System Memory test group in the Dell Diagnostics.
Did any of the diagnostics tests fail?
Yes. Contact Dell for technical assistance.
No. Go to step 3.
  1. Turn off the computer and peripherals, disconnect them from their electrical outlets, wait at least 5 seconds, and then open the computer cover.
  2. Rotate the power supply away from the system board.
  3. Replace the memory module(s).
  4. Close the computer cover, reconnect the computer and peripherals to their electrical outlets, and turn them on.
Yes. The memory module(s) were defective. The problem is resolved.
No. Contact Dell for technical assistance.
Nov 06, 2007 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
Top Generic Memory Computers & Internet Experts
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
