https://fuse-box.info > mazda > mazda-6-gg1-2003-200...
Here you will find fuse box diagrams of Mazda 6 2003, 2004, 2005, 2006, 2007 and 2008, get information about the location of the fuse panels inside the car, and ...
theres a panel under the dash on the passenger side, take that off and theres a fuse panel. the fuel pump fuse is there, probably the relay is there too, but check the fuse first.
The relay is inside the engine computor. The fuse should be one of the ecm fuses in the fuse box under the dash. Check your wires on the throttle body that go to the injectors. Have seen air filters rub through the insulation and short them out, especially of the gasket for the air filter is missing or broken.
under the hood somewhere on one of the side the fireway normally one side/ firewall is fuses and relay for powering inside the car. the firewall on other side of car underhood is whee the relays and fuseable links are located vu can tell the 2 apart
This is what I could find. It doesn't have a steering whee radiol control fuse but has 2 fuses for the radio. It seems to be the same panel across the board for BMW's. 4x4's, diesels, gas, 6 and 8 cylinders, etc. Hope it helps.
