Sony PFM-42V1 42 in. HD-Ready Plasma Television Logo
Posted on Aug 08, 2011
Sony pfm-42v1 problem, its has double image top and bottom
1 Related Answer
A
Anonymous
  • Posted on Aug 10, 2008
SOURCE: Sony pfm-42va double display from top to bottom
eex
2answers
Where is the coaxial connection on the Sont PFM-42V1 model made in 2003
Look at the back of the tv. Bend down and then look up and you will see the coaxil connection and possibly other rca connectors as well.
My sony pfm-42v1 no pictue
turn it off for around 30 min..try it again, then let us know what you find...could be a control board issue
2helpful
Sony PFM 42V1 Vertical black line
you have a bad lcd panel call sony they may help
7helpful
Sony pfm 42b1 negative picture
I have a Sony PFM-42v1 and it does the same thing, look in your tv menu for picture inversion, usually under screen saver. What it actually does is reduce the chance of screen burnin. By reversing the image it sort of resets the hot areas, brightest colours and the cooler areas being dark colours, switches them around ( negative ). This cools the hot spots and heats up the cold spots.
There should be a option to turn it off, mine and I guess yours as a default is ON, mine has the ON, timer and OFF options.
Hope this helps, please let me know if you need more info.
russell
Cannot even find where to plug to aerial point into the sony plasma flat panel display tv PFM-42V1
PFM-42V1 has no ability to receive channels through aerial / cable.
You can hook direct video cables from dvd player, vcr, PC etc.
Sony PFM-42V1 bottom half of the screen is a blurry ghost image of top
The Sony Plasma designe not to repair at component level your problem I believe in YSUS PCB you can adjust a few variables resistors on this PCB make sure to mark on the spot before turn you can alway go back to original point, set your plasma on normal channel turn the variable resistor slowly and observe the picture any spot will effect the picture if you can not adjust you need to replace a new PCB
Let me know how you go
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
