Question about Dryers
I have a simpson maxidry 326 dryer. It cuts out and stops tumbling after 5-10 minutes,it seems to cool right down and then I have to start it again. So if for instance I put it on the hot setting and say heavy duty or another setting for that matter it stops.
  • Anonymous Mar 24, 2014
    can anyone help
Check if the drier is blowing out air from the air duct. If not, the fan pulley is likely broken. With no way to cool the machine the thermostat will be shutting the machine off as it overheats.
Posted on May 09, 2009
I have a Simpson Maxidry 362 3.5kgs. The timer has stopped working. If I put it on 30 minutes it remains stuck on 30. Can I repair?
Hi, I owned a dryer a few years ago and the timer switch became faulty on that so i pulled it out and took the switch to a repair store where i bought a new timer switch.....CHEERS..
Mar 25, 2016 | Dryers
Can you please tell me where I can get a Simpson Maxidry 1000 user manual or any other kind of manual for this dryer?
Try this link:
http://fasterbetterdownloads.com/simpson-maxidry-1000p-user-manual/
Jun 20, 2015 | Dryers
How to wire Simpson 1200S dryer motor
Check with Simpson directly to obtain the diagram.
Jun 10, 2014 | Dryers
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
MY SIMPSON MAXIDRY 362 3.5KG HEAVY DUTY DRYER KEEPS OVERHEATING AND CUTTING OUT. WHEN IT STOPS AND I PRESS THE SAFETY SWITCH IT TURNS ON AGAIN BUT ONLY FOR 10 MINUTES. CAN YOU ADVICE ME ON WHAT I CAN DO...
I would check the exhaust pipe outside and make sure it is not blocked and has good strong air flow while the dryer is running. If there is not good airflow, then clean out the exhaust hose and pipe. There could be other problems, but I would start with this.
May 01, 2010 | Dryers
Broken door on simpson maxidry 362
when it comes to whitegoods old is good. your dryer will outlast most new ones. buy the new parts it will b lot cheaper than a new dryer. not much goes wrong with the old simpsons. please reply if u need more help
Apr 11, 2010 | Dryers
Simpson Maxidry 457 not heating
Check thermal cut outs/ Element Should read around 32 ohms on a multimeter if its ok...
Apr 09, 2010 | Dryers
Replacing the belt on a simpson 362 maxidry
Check out applianceaid.com good easy site to follow
Apr 19, 2009 | Electrolux Dryers
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
Dryers Logo
274 people viewed this question
Top Dryers Experts
