Question about GE JSP42 Electric Kitchen Range
Oven door lock is stuck I have a GE oven and after using the 3 hour cleaning option the door will not unlock
  • DOUGROY Sep 03, 2008
    Thanks, for the help I have done the above stuff you spoke of but it did not work I finally undid the lock mecanisiom to get the door open but when I hit the bake button it says door
  • 639 Answers
Peace
ngfam1 at your service.
Try turning the power off at the fuse or circuit box and then with it off open the door!
If no then turn the power on again and try to open the door!
There may be a section in the user guide too!
I am not there to give hands on diagnoses.
But I can give you a good service that is nation wide!
A&E Factory service .
They answer 24/7 to make appointments!
And have a reasonable service charge of $75 around our area
Remember though, if the unit is 10 years old or more it may not be advisable to put good money into bad!
New appliances are much more efficient and pay for them selves in only a few years!
Bless You,ngfam1
Please give me a good rating in our fiya.com sight before you sign off!
Posted on Sep 03, 2008
My GE wall oven is stuck on lock mode. I cancelled a self clean (I know, big mistake) and after cooling down it still won't unlock. I've cut the power and still nothing. It's been 3 days! Trying to avoid...
Try putting it back in self clean. Listen to see if it locks. then cancel the self clean. It could be the self clean lock motor has gone bad. The lock hook can be moved to unlock the door by inserting a stiff wire like a coat hanger between the door and the oven and moving the latch over to unlock the door.
Nov 07, 2014 | Ovens
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
My GE oven is stuck locked after the cleaning cycle....it's been 12 hours
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Apr 26, 2011 | GE Ovens
We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature)
Thank you and thanks for using fixya
Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
Oven door remains locked after using the oven cleaning feature
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 12, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
GE Electric Double Oven Door Will Not Unlock
heatman101
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
