Is it the transmission or the clutch assembly sticks maytag Washer
Is it the transmission or the clutch assembly sticks maytag topload LAT9206BAE
vest6
  • 196 Answers
SOURCE: No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Posted on Jan 13, 2008
docjohn174
  • 943 Answers
SOURCE: maytag washer lat9206bae drum will
hi thanks for the question looks like you have a bearing problem the dru wont turn its an expensive repair for that model of maytag they were not a good model thanks for the question the appliance doc
Posted on Sep 27, 2008
dh1200s
  • 335 Answers
SOURCE: maytag neptune tl topload washer
You are going to have to pull the front cover off the machine and do an inspection for that water leak here is some support info.
The Service Manual for reference. Sears Parts Direct for reference.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the SM
About the “OF” alarm if it’s a valid error code it seems to be undocumented. Let me run this by you. I wonder if it could be something like valid “OP” error code with a bad segment of the second portion of the LED display. If your FAV6800AW would allow you to enter a Spin Only cycle the display would read “10” min for the countdown timer at the start of that cycle. Can you put the washer in a Spin Only cycle and see if the console display indicates “10”? You can then cancel the spin only cycle.
How did you make out with your previous “OD” error?
Rich
Posted on Jun 10, 2009
  • 2468 Answers
SOURCE: Maytag Washer LAT9206BAE does everything but
look for an obstruction or kinks in the drain lines from the tub outlet all the way to a plugged drain hose or broken impellers in the pump
Posted on Mar 25, 2010
  • 155 Answers
SOURCE: Leaking water Maytag Washer
If the connecting hoses is not a problem then it is probably be the pump present inside the machine.It helps in moving and draining the water.If it is not working then such problems might arise.It is best that you ask the plumber to replace it instead of you doing it
yourself.
Posted on Apr 10, 2010
How do I open front panel of Maytag washer ?
2 screws at bottom of front remove. Then pulling from bottom towards you until the clips at the top of the front panel clear the top of the machine.
Nov 20, 2016 | Maytag Washing Machines
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Transmission or clutch assembly not engaging due to going out or slipping.
Sep 28, 2014 | Maytag Neptune Washing Machines
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
Maytag neptune toploader won't finish cycle code dc. What does dc mean?
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not agitate, during this step, clothes just sit in water filled tub. once timer moves past this function, it continues to spin and drain like normal. I just put in a new timer, thought that was...
Hi, anytime the washer doesn't agitate at the time that is ordered to , this will confirm that the clutch assembly has failed. the clutch is part of the drive assembly and it works within the gear box(transmission. you will have to replace this device. there is also a shift aculator that works with the transmission as well. this could be an issue also.
I recommend inspecting the drive Assembly and clutch for broken or stripped components.
May 17, 2009 | Maytag Washing Machines
Washer not spinning enough to ring out cloths
I have the same problem with my Maytag LAT8506AAE machine. Do I need to fill up any oil after the seal replacement?
Jan 24, 2009 | Washing Machines
Maytag washer lat9206bae drum will not spin switch motor pump ok belts smoke but drom pulley frozen
Sep 26, 2008 | Maytag Washing Machines
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
Maytag washer sav models
If you have the topload maytag as listed, It is possible for a transmission to have both symptoms, but it doesn't usually happen as you describe. If something came apart inside the clutch causing the shaft to pull up and keep the brake released, but also allowed the clutch to slip, this is possible.
I would suspect a brake or thrust bearing or both before a transmission. If you are able to turn the basket easily by hand, the brake is not applying for some reason. The thrust bearing will wear down so that it doesn't completely release the brake causing a slow spin. I find these two parts to cause more trouble than transmissions, but I do find bad transmissions occasionaly also.  Post back if you want to know how to check them.
Oct 17, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
