Question about Haier hwr10xc6 Air Conditioner
Haier AC How do I set to run at certain temp. It seems to continue running even after temp has been reached. Thanks ...Lori
  • 2,120 Answers
Open the front cover or take it off, make sure that the brass tubing is 1/8" away from the coil fins at it's entire length.
Posted on Dec 30, 2008
Why is the AC still running after the set temp has been reached?
You may be hearing the fan run. Normally the fan will run 30-90 seconds after the unit has reached temperature to give you the air that you just paid to condition.
If it is actually the a/c running, that is because the thermostat internally reads in tenths of a degree. So when you set it to say 70 degrees, it is really set to 70.0 degrees. The thermostat will show 70 degrees when it reaches 70.5 degrees and continue to run all the way to 70.0 degrees
Welcome To the Best HVAC
Oct 10, 2014 | Heating & Cooling
Why has it stopped running, but still shows temp and humidity?
I may have reached the humidity level that you have set it at. Press the HUMIDITY button until it says "Lo". That should put you into continuous run mode.
Good Luck.
Jun 09, 2014 | Haier DE65EJ Dehumidifier
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
Radiator fan not stopping even when i turn off the car and remove the keys. this is leading to battery drain
Radiator fan is supposed to start working after the temp reaches a certain limit. And it is supposed to run til the temp reaches a certain lower limit. So when you switch off the engine and walk off the fans must be running to cool the water to that lower limit. Unless you seen that it runs well past that and does not stop at all. Does it start running when you start the engine? And runs throughout the time the car is running, which it should not. The relay seems to be out. It is this relay that controls the running of the fan. or the temp gauge. If the temp gauge is giving wrong temp then the relay has to keep working. Please check both, the relay and before that the temp gauge.
Dec 14, 2009 | 2000 Volkswagen Beetle
AC turn off before it reaches the desired temp
Hi there. I assume the indoor fan runs continuously until the house has cooled down. Clean the condenser. (outside unit)
Another possibility is that the system is getting low on freon. Check for leaks with soapy water at all joints and fix them.
Jul 13, 2009 | Ruud UAKA060 Air Conditioner
Delonghi cf210 when setting temp it dosnt give any heay
just bought one.It looks like the thermostat has problem. Set at 78 F, it runs forever and the room temp is 72F. Set at 79F, it runs, room temp shows 73 F, sometimes 75F or 77F. The Ac is on then off every 5 minutes even the desired temp (is set) reached. Lousy machine.
Jul 27, 2008 | DeLonghi CF210 Portable Air Conditioner
AC thermostat does not control AC. AC runs continuously. Have to shut system off to stop AC.
are you using the old coventional thermostat? using mercury
or was it digital?
chances are the reason it is not stopping because it can not detect the right temp inside your house, if you have set this for example 74F AC would run continouisly until it reaches that right temp, until that time, it would surely not stop,
check for any windows, door that might cause some air leaks inside your house for a start, close all exhaust fan and see if you can see any difference, if not this might be the right time to change for a digital temp control, it not that expensive and easy to install
Jul 25, 2008 | Heating & Cooling
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Haier hwr10xc6 Air Conditioner Logo
57 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
