Question about Canon EOS-AE-1 35mm SLR Camera
Shutter squeal, Canon Cough a1 Ae1
Can anyone tell me what I need to lubricate to cure Canon Cough?
This is in german. Look hard at the pictures. You only need to remove the bottom plate. Use a hypodermic needle loaded with just one drop of non-acidic oil. Practice first. Stick the battery back in an operate the shutter 30 times. leave the camera overnight upside down.
www.aldo-net.com/Canon/
Running the text through Babel will give you a good idea. It does work.
Bob-S
Posted on Oct 07, 2008
Canon mf8380cdw squeals when starting up
Squeals are often a lubrication issue. Can you tell where the squeal is. Front, back, side. sometimes it's hard to tell because sound bounces and could be from anywhere. Does it go away right after first print or after warm up cycle?. Delicate equipment does operate better in the proper environment. The manual will usually tell you what room temp machine will work better in.Try to get a better idea of where noise starts Depending on how long you have had it and the print count it may need to be checked out by tech..
Feb 25, 2014 | Canon imageClass MF8380Cdw Wireless Color...
Need manual
Refer to my answer to your other post.
Dec 02, 2011 | Canon Eos 10d 20d 30d 1v Ae1 A1 Ef Ef-s
Free owners manual ae1 canon film camera
You may download a copy of the AE-1 manual here.
If you have an AE-1 Program, you may download its manual here.
My canon AE 1 shutter is not firing, the button will press down but when I pull back to advance the camera it just won't work.
That is normally a classic indication of a failed battery. Try a new 4SR44 battery.
If you are absolutely certain that it cannot be the battery, then your camera is most likely in need of a full professional CLA service (Clean, Lubricate, Adjust). The internal lubricant films dry out over about 30 years of use and gum up the mechanism.
A professional repair costs far more than the camera is worth, and most repairers won't attempt this on your non-functional model unless you agree to pay up front due to the possibility of carrying out work only to find a more serious fault (unusual on the AE1 as it's well built, but still possible). Although the repair may not make economic sense, if it works then you'll have a camera which should be good for many more years and which can still produce results which will put a digital SLR to shame, especially if you shoot on transparencies and then scan them. Plus there's all those nice, cheap/free, used FD lenses lying around...
Oct 08, 2010 | Canon EOS-AE-1 35mm SLR Camera
Ae1 when i advance film the shutter releases abd takes a photo
You have bad mirror release magnet.
The magnet became weak and not holding the mirror so when you wind, the mirror goes up and takes pictures or releases the shutter by itself.
Apr 27, 2010 | Canon EOS-AE-1 35mm SLR Camera
Canon Squeal
This is common on the A series Canon cameras. It's a flywheel governor on the side of the mirror box that needs to be lubricated. We do that for $48. Let us know if we can help.
Crystal Camera Repair
Asheville, NC
www.crystalcamera.com
Dec 30, 2008 | Cameras
Canon ae1 shutter button problem
Usually cleaning the contacts becomes an effective solution, but if the problem continues take the camera to the service. All shutter problems requires professional care.
Sep 23, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon AE1 Shutter Problem
It could be a simple issue with the shutter magnets, or something more severe with the electronics. What does the meter needle do when you push the shutter release down? With the speed dial set at 1/125 or higher and no lens, the needle should move fairly high. If it pegs to the bottom right away, that is a bad sign.
You can check the magnets from the bottom with the cover removed. (2 screws) You can release the mechanicals of the shutter by pushing the silver lever arm (located next to the plastic shield around the magnet on the rewind side of the camera) toward the front of the camera. Be mindful of the spring attached
Sep 17, 2008 | Canon EOS-AE-1 35mm SLR Camera
Meter on ae1 not working when aperture setting adjusted
On that camera the needle is not supposed to move when the f-stop ring is turned. It should stay on whatever number it is on and you should set the ring manually to whatever the needle points to.
That camera was really not made to be easy to use in the manual mode. I guess Canon thought everyone would just use it in Auto.
CameraRepairs
May 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shuuer stuck down, lever wont advance
The Canon AE-1 has an electronic triped shutter and cocking system and requiires a battery to function. So yes the battery is required. Goog luck!
Aug 26, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
2,578 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
