Question about X2Gen MG19MY 19" LCD Monitor
X2gen 19 inch monitor
When I start up my PC the monitor starts to buzz and continues for about 15 minutes. Creates problem with my pc performance and with a TV that is nearby?
Any thoughts on whats going on?
  • tmlorenzo Sep 20, 2008
    Thanks for the help. I found it to be a problem in the display itself. The disturbance did eventualy lock up the computer. Tried another display everything worked fine. Bought a new one!
    Thks
    Scholar:
  • 188 Answers
It sounds like a heat problem in the monitor. It could also be a computer graphics problem. Leave either the computer or the monitor on for a while and then turn on the other device. try to discover which is needing to be warmed up. The buzzing and problems with the other RF devices around mean that the monitor or computer is emitting frequencies so it will affect the TV and maybe the computer. I found my computer emits these frequencies. I can't listen to AM radio when the computer is on.
Posted on Sep 20, 2008
Buzz coming from speakers. x2 gen 19 inch lcd been working for 2 years on old xp and now win7 no problem with win7 for 4 months before this. checked for updated sound drivers. plugged in usb powered...
Buzzing is usually caused by bad audio ground connection. Try insert and reinsert the audio cable first. It can also be the sound card. Try using the MP3 player as the sound source feeding the monitor, if it still bad then it can be problem in the DC filter caps in the power supply, or bad sound IC in the audio board inside the monitor. Please post back what you find.
http://s807.photobucket.com/home/budm/allalbums
May 07, 2010 | X2Gen MG19VT 19" LCD Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Monitor says out of range when i start windows 7
When you start the computer, press F8 continually until you get a menu that will allow you to start in VGA mode.
You apparently have the resolution set too high.
You may be able to reset it in safe mode, also.
Nov 04, 2009 | X2Gen MG19VT 19" LCD Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
X2gen 19 inch monitor wont power on
Had the same problem with mine. First you need a volt meter (radio shack about $15). check the push in connector and make sure it has coming from it.
Place you meter on DCV for DC voltage, Then place one lead in the end of the plug in the hole. (will not fit all the way so will need to hold it there, Put the other lead on the shiny part of the plug. If you get a reading of 12 volts +/- 1 volt your good. Depending on which lead is were you may get a minus reading this is fine as if you switch your leads around it will go positive. you must have the cord plugged into the wall to do this test. You will not get shocked or anything as 12v is not enough to hurt you.
If you have the 12 volts the problem is in the monitor on the male plug or on the board. this takes more to fix and must take the back off the monitor and fix the connection or replace. I did this to mine and it is working right now.
Apr 10, 2009 | X2Gen MG19MY 19" LCD Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
Sound problem (I have vista business)
have you recently upgraded to vista?
maybe you need to install new drivers for your sound on pc?
maybe your sound card is not compatible with vista?
if you write back with more details i can give you a bit more advice.
Feb 25, 2009 | X2Gen MG15VT 15" LCD Monitor
X2gen 19 inch wont turn on.
my Acer Orbicam that takes picters and vidios stopd working just like that and i dident do enithing rong it just stopd working please can someone help me
May 30, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MW19U: Start "Auto Adjusting"
This sounds like a straight hardware issue. However, to be certain, try to attach another monitor to this PC, and if it works properly, you will know that there is nothing wrong with the graphics card/driver or other related component of the PC involved. (Also make sure you are using the proper type of cable - analog/digital - for the connection.) Also suggest switching out cables to eliminate that. Further, you could try to see if the monitor functions properly when attached to another machine. If the machine is not functional and another is, that will confirm that the issue is hardware-based.
Unfortunately, X2Gen has declared bankruptcy (see http://x2gen.com/) and there is no way to go back to the manufacturer for either support or warranty service. If you are still within a given time frame with either the retailer, or perhaps through a credit card company, this would be your best recourse. Here is the link to the form via which you could file a bankruptcy claim: http://www.x2gen.com/files/Claim.pdf. Hope this may help, if you can't get reimbursed through some other means.
My experience with this type of issue is that the hardware has gone bad. Particularly with the nature of your problem, it seems that it is not a minor problem, and does not appear to involve drivers or other software-type fixes. If you could get a professional tech to repair it, the cost would most likely be more than replacement of the monitor. Sorry for the bad news, but I don't think there is a better solution.
If the monitor continues to behave in the same manner, I think that is absolute confirmation that you have a "nonnegotiable" hardware issue. If not - in other words, if you see something different with switch of connections/machines, there could be a graphics card/driver or other issue that we could work on further.
Please post back if you need additional assistance, or this does not answer all your questions. Otherwise, thanks for using and rating FixYa!
May 23, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen 19 inch LCD Monitor problem
Its the problem of the main display board. Not the SMPS. There will be another board inside. You have to replace the board or If some body may fix if you have spare parts of the board.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
74 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
