Master
- Posted on Aug 08, 2011
Re: I can not find driver suitable for scanner CP-HR7X to...
Hello mahisa.
You may try uninstalling the existing drivers\software and install them in the Vista Compatibility Mode and check if it helps. To do so, follow these steps.
Right click on the setup file (setup.exe for the drivers) and select Properties. Click on the Compatibility tab and check the box which says Run this program in compatibility mode for. Select Windows Vista (Service Pack 2). Click Apply and OK. Right click the setup file and select Run as Administrator and follow the normal installation procedure.
