Question about Philips HDD1630 MP3 Player
MY PLAYER GOGEAR 1630/17 SCRENN FROZEN GOGEAR
  • 4 Answers
Try resetting the device by pressing the on/off button and the volume up button at the same time.
Posted on Oct 18, 2008
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
My player has frozen. Everything I've tried, and every button I've pressed, doesn't work. Need help!
The firmware of your Philips GoGear SA1948 MP3 player has become corrupt.
Fix it by reflashing the system software, which you will find at the Philips website here.
Mar 14, 2011 | Philips GoGear SA1948 (4 GB) MP3 Player
Gogear Vibe is ''frozen''
I just reset it, and it works great. Need to keep it updated.
Jun 12, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips gogear is frozen
Press and hold the Power On/Off key and the Volume + key for a couple of seconds to reset
If that alone fails, run a Repair in the Philips Device Manager
-Tha Mp3 Doctor
Dec 27, 2008 | Philips GoGear HDD6330 MP3 Player
Frozen gogear philips mp 8gb
thank you for your concern: i fix it and the only way its to let the gogear run of battery and then you have to run the cd so you can download the songs from the itune library.
Jul 26, 2008 | Philips GoGear Flash MP3 Player
Frozen screen
Hold up on the volume control, and down on the off switch at same time...
Mine will no longer connect to pc...
Apr 28, 2008 | Philips GoGear HDD6330 MP3 Player
Frozen screen
reset the gogear pres the power and volume + at same time
Apr 19, 2008 | Philips GoGear HDD6330 MP3 Player
Frozen screen
The player can be reset if frozen by pressing and holding POWER ON & VOL+.
If the problem persists the only way to fix it is with Philips Device Manager. There is no Linux version available though.
Perhaps you can hijack a friends Windows PC to run it.
Apr 11, 2008 | Philips GoGear HDD6330 MP3 Player
My philips SA6045 is frozen
Reset the player first by inserting a small paperclip or other device into the rest hole and holding for several seconds (when the player is turned on).
If that fails:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Feb 09, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips HDD1630 MP3 Player Logo
120 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
