Question about Hotpoint WMA40 Front Load Washer
REFITTING THE BELT ON HOTPOINT WMA 40
PLEASE HOW DO I REFIT THE BELT ON MY WASHING MACHINE
    Problem Solver:
  • 18 Answers
Place it on the motor pulley and then guide it around the drum pulley. It will have come off for a reason which if you do not correct will cause it to come off again. Lay it flat on a table - if it does not lay flat - replace it. Check the pulley on the drum does not move from side to side. (problem with pulley or drum bearings)
Posted on Jan 02, 2009
How do you refit a pump on a wd640?
Unplug the machine from the wall outlet,
Remove lower rear panel of washer. Locate the pump, remove the hoses onto the pump and disconnect the pump from the machine. Refit in the reverse order removal, making sure that all bolts, clamps and screws are tight. Check for leaks before refitting the cover.
Mar 13, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpoint Ultima WT761 Washing machine. The belt has not broken but is damaged and the edge is stripping off. It has come off the drum and motor spindle. Clearly its time to get a new one which I...
not absolutely sure of your exact model, but most washer belts on put on by putting them on the motor the stretching to the tub pulley and holding it there while you move the pulley which then stretches the belt to fit for you.
May 05, 2017 | Washing Machines
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Dec 21, 2009 | Hotpoint Washing Machines
Refit belt
There is provision made for tensioning the belt.
It is self tensioning.
Remove top cover and rear panel.
With the washer tilted away from you,(get someone to hold it for you)Fit the belt round the motor pulley first, then slowly feed it round the drum pulley, turning the pulley at the same time, watch your fingers as it will be very tight, and just keep going until the belt is on, if it slides off, just start again.
Good luck.
Dec 13, 2009 | Hotpoint WMA35 Front Load Washer
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Where do ilocate the filter on a hotpoint wma 13 washing machine
You will find the filter inside the large black sump hose fastened to the bottom of the tub..
Remove the lower panel at rear of washer, locate hose and remove same ,remove and clean filter inside hose
Refit filter and hose and test.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine not spinning
Its a pain on this model but heres how. First remove plate at back of machine. Remove belt and two bolts holding motor (13mm).Unplug motor and remove. brushes are at back end of motor in plastic housings. after refitting motor replacing belt is where the fun begins. Put bottom end on first and feed round pulley. ouch
regards
Dec 04, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machine Belt Bosch WFF20
Peace Friend,
ngafm At your service!
You asked,
The belt has come off my Bosch WFF 1800 washing machine and I'd like to try and refit it - what should it go around?
The belt did not just come off! there is a reason it came off!
You may want to put it back on. But the problem may not be just the belt.
Sometimes the belt comes of prematurely due to another problem in a Bosch. You bough the top of the line machine and it deserves the top of the line service.
Or you may find your self paying twice for a job that cuold have been done once the right way!
Please save your self some money and get service on this particular machine!
Bless You,
ngafm
You are welcome to write me and let me know how it goes.
Please give me a good rating for this fine advice I just give you, as i would my brother.
Sep 07, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Hotpoint WMA40 Front Load Washer Logo
283 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
