Question about Sony Handycam DCR-PC1000 Mini DV Digital Camcorder
Sony drc-pc1000 camcorder- tapetransport noise
Very bad sound and tape transport noise (capstan part) Reaction sony service: it's belongs to a dv-minicamcorder, some have more noise and some less. So, some extra you did.nt pay for: rumble! And that for a lot of money, shame!!!!!
4 Suggested Answers
JoeO700
  • 80 Answers
SOURCE: not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Posted on Mar 01, 2007
ctf1800
  • 4402 Answers
SOURCE: Tape stucked in the Sony DCR-PO101 NTSC Handycam
nope
Posted on Jan 21, 2008
  • 23 Answers
SOURCE: connect Sony Handycam DCR-PC5 Mini DV Digital Camcorder to my Laptop
try to install the cd software of your sony handycam into your laptop..
hope it will help thanks...
Posted on May 27, 2008
  • 586 Answers
SOURCE: I have a Sony handycam DRC-HC26. After placing the
The mechanical of tape loading compartment is misaligned and it needs readjustment which is a bit technical issue. Please contact any expert for mechanical adjustment of tape loading path assembly.
This will solve your problem.
Thanks.
Posted on Nov 24, 2009
0 characters
1 Points
Describe your Handycam DCR-PC1000 Mini DV Digital Camcorder Problem I need to find a repair shop for my sony DCR-PC120. I first received an error message C:32:30, NOW THE DOOR TO MY CASSETTE COMPARTMENT...
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 24, 2011 | Sony Handycam DCR-PC1000 Mini DV Digital...
Whenever I insert a new video tape on my Sony Handyman DCR-TRV120, it says "C:31:23" and it tells me to eject the tape. Once I take out the video tape, it rather has the film outside of the tape,...
You have a transport problem with the tape feed. If you are up to working in small spaces without damaging adjacent parts, you can try and clean the pinch roller and capstan drive system with alcohol on a Q-tip. Sometimes, there are special cleaning tapes your can purchase that will do the same thing. Assuming that the transport is dirty, you may have a shot at it. If it's excessive wear instead, it's shop time. One more thing. DO NOT USE A CRINKLED TAPE IN YOUR CAMERA. IT WILL TEAR UP THE VERY DELICATE TAPE HEADS PERMANENTLY.
Feb 04, 2011 | Sony Handycam DCR-TRV19 Mini DV Digital...
C:31:23
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Sep 20, 2010 | Sony DRC-PC1000 3CCD MiniDV Handycam...
Tape will not load; Error code 31:23
You may try the following troubleshooting steps:
Remove the battery of the Camcorder for one minute and re-insert the battery to check whether it works.
You may try resetting the Camcorder by pressing the RESET button located on it.
You may also check whether the issue occurs for all the tapes.
If the issue occurs with all the Tapes then it seems that internal parts of the Camcorder are malfunctioning.
Hence, the Camcorder requires service.
Jul 14, 2010 | Sony Handycam DCR-PC1000 Mini DV Digital...
I have a Sony handycam DRC-HC26. After placing the DV tape the tape refuse to load into the tape compartment and as such the tape door cannot be closed. Please advise.
Thanks.
Nov 24, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony camcorder has knocking noise in recording or playback
Try using tapes of different sizes. a big tape may be exerting stress on the mechanism
Feb 27, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Jvc miniDV 28x Optical Zoom
clean all brown oxide off capstan roller with 70% alcohol and Q-tip. Its the skinny silver axle that the rubber roller comes into contact with when the tape loads. This is what pulls the tape through the transport. also clean heads with head cleaner tape. If your head is dirty, the tape will wrap itself around the drum and cause a transport error.
Jul 14, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Jvc gr d290
In the case no CAPSTAN FG is produced in
the capstan rotation mode for 2 seconds or
more. This error is defined as [E06], and the
mechanism mode is shifted to STOP with the
pinch roller set off.
However, no CAPSTAN EMG is detected in the
STILL/FF/REW mode.
1. The CAPSTAN FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the CAPSTAN FG pulse generator (MR
element).
2. No capstan control voltage is supplied to the MDA.
3. No power is supplied to the CAPSTAN MDA.
4. The capstan cannot be started or capstan rotation is
stopped because tape transport load is too high.
1) Tape tension is extremely high. (Mechanical locking)
2) The tape is damaged or soiled with grease, etc.
May 12, 2008 | JVC GR-D290 Mini DV Digital Camcorder
C:31:30
FG fault when starting capstan.
Make sure battery is fully charged or a/c cord is used. Turn power on, and push reset button, try to eject tape again. Your capstan motor may be dead.
Jan 03, 2008 | Sony Handycam CCD-TRV318 Camcorder
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony Handycam DCR-PC1000 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
