Question about Bauknecht Dishwashers
Bauknecht GSX 4756w when I switch it on and set the dial to the wash setting, I close the door and it sounds as though it is about to start but after 30 secs just starts beeping. When I open it the cycle setting is always reset to rinse. Can't get it to switch on at all.
    Master:
  • 521 Answers
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  6. Dishwasher child lock help Bauknecht GSX 4756w
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
  • 1,029 Answers
Can you
Unjam the motor and the pump then Test the motor andthe motor start relay also Check the drive belt
  • Starnley Johnwells
    Starnley Johnwells Sep 04, 2008
    you have to open it to do that,can you fix it your self
  • 4,472 Answers
How long have you owned the unit? Are you able to repair this yourself at all or troubleshoot?
Thanks,
Lee
  • Lee A.
    Lee A. Sep 03, 2008
    I would recommend a professional to come and fix the unit unless you have technical ability. I can assist you in finding service if I know your location.
    Thanks,
    lee
How do I dry only
When using the WD-1000 as a Dryer only, are you turning the rightmost knob Clockwise to the correct starting point?
Looking at the periphery of the knob, at the bottom, see the elongated "sausage" shape, outlined in blue? Turn the knob so it passes "Stop", and points there.
At the end of a completed Wash Cycle, that is where the pointer will be pointing. Once there, the machine switches automatically to Dryer Mode.
As long as the middle dial is set to a timer length greater than zero, the drying begins. I recommend turning the middle dial to somewhere around 2:00 o'clock, which corresponds to about 90 minutes if I remember correctly.
(You'll notice that is in the "Orange" area, meaning Full Heat - which is always fine because it never gets too hot anyway)
So, turn right dial to point to the "white sausage" at the bottom of the dial; Turn middle dial to 90 mins, or so; (Left dial only controls "Spin" speed - just set to max); and close the door. (It should begin drying)
Feb 14, 2015 | Malber WD1000 Front Load Washer/Dryer
Kenmore dishwasher will not start
The most probable cause is the door latch (or switches in the latch) are not working right, and the controller thinks the door is open, even though it is closed.
Aug 13, 2012 | Kenmore Dishwashers
Close door push start and it says door
Possible that the door safety switch is not contacting and is defective. Remove power and check from inside the unit for the continuity of the door switch.
If open it can be shorted for a trial run to confirm and then replaced.
Jul 05, 2012 | Frigidaire Washing Machines
Maytag dryer waont start when you push start button
Try opening and closing the door a few times it might be the door interlock switch, Are your plugs fused like in the UK. If so check fuse, or there will be a safety fuse inside the dryer which has blown in which case it will have to be examined by a qualified repairer.
Nov 13, 2011 | Maytag Performa PAV3200
How do i reset my bauknecht oven clock?
This is what worked for me:
1) hold down the "Select" button for 5 seconds till the display starts flashing
2) use the right hand dial to set the hour
3) press the "Select" button
4) use the right hand dial to set the minutes
5) press the "Select" button
Mar 20, 2010 | Whirlpool GBS277PDS Electric Single Oven
LOADED MY BOSCH CLASSIXX 6 1400 EXPRESS CLOSED THE DOOR THEN TRIED TO PUT IT ON A PROGRAMME AND IT CAME UP -0- AND IT WOULD NOT START NO TIMES WAS COMING UP WHEN I TURNED THE DIAL ONTO A PROGRAMME.PRESSED...
this sounds like a door lock issue if the machine does not detect the door has closed properly you will get the same symptoms, try slamming the door shut (not too hard) if machine starts but then does the same thing next time you use it will need new lock it will have gone out of calibration.
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
1999 Ford Ranger air won't blow out of vents, defrost, or floor
SOUNDS AS THOUGH YOU HAVE A BLEND DOOR STUCK CLOSED IN YOU HEATER / AC SYSTEM SOMEWHERE. CHECK THE VACUUM MOTORS THAT OPERATE YOUR BLEND DOORS ON THE SYSTEM.
Dec 04, 2008 | 1999 Ford Ranger SuperCab
Dishwashers Logo
368 people viewed this question
Top Bauknecht Dishwashers Experts
freddyfox
ray gallant
Kevin Getz
Kevin Getz
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
