Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Sony DCR-HC40 Battery Charging Problem Hi Mates - I did purchase a Sony DCR-HC40 camcorder around an year back and it was working superb till few days back. As of date, i am facing a problem where the camera battery is not getting charged. It happened suddenly and abruptly as it was perfectly fine (with a back up of around 40 min to 1 hr) but not it is not getting charged up at all. I being a novice in this feild am not able to gauge whether its a problem in - a) The wires or b) The battery or c) The camcorder itself Pls help me.
    Master:
  • 473 Answers
The problem with the charging appears to have been a bad connection to the "brick" power supply. I jiggled the connections and the charge light blinked and came on. When I jiggled a bit more it went off. Further fiddeling (that's like a jiggle only more scientific) resulted in the ability to charge both batteries that I have. Everything at this point seems OK.... We'll see..
Posted on Sep 14, 2005
    Master:
  • 473 Answers
Bought an external charger since out of warranty repairs are running about the same price as a new camcorder. Since you have 2 batteries, you can leave one in the charger and switch when its depleted.
    Master:
  • 473 Answers
Had the same thing happen to me. Went out and bought a new battery and it, too, does not charge. Apparently something messed up with the in-camera charging system. It will charge for several minutes (charge light illuminated) and then the charge light goes dark. Battery gage shows that there is virtually no time left on either battery (old or new). Anyone have any ideas other than a trip back to Sony?
SOURCE:
I have a camcorder sony dcr-hc40 I need the cable that go to the tv
Required AV cable for Sony DCR-HC40 is available in Part Store.
Thanks.
Sep 11, 2009 | Sony Video Cameras
DCR-HC40 LCD works, but Touchscreen doesn't. I was able to calibrate once -- but din't hold settings. I cannot calibrate.
hello its ruttine problem ,just change the lcd FLAP and you can use the touchscreen.its not to wory about that
Aug 25, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony DCR-SR62 screen rolls continuously
HAd the same
It's a flex wire connecting LCD with camcorder. got from the repair shop. did it by miself workes like new. it'very common in this kind of sony.
Aug 07, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Document for downloading to laptop form sony handycam dcr-hc40
Check all updates and helpful news about DCR-HC40 on Sony Support.
You will get answers of many questions about this camcorder.
Jan 04, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
Operation
if you power the camcorder from the call socket, if it works that mean the battery has bad.
May 12, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
NP-FH100
the 'charging' hole is for you to charge the battery. the 'fh' hole is to power the camcorder. no need to put battery on camcorder in either situation but it is convienent to attach the battery to camcorder.
Dec 12, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony HC-40E Charging Problem
Try loosening some of the screws on the handycam, to allow you to prise open the case slighly, allowing access to the strip coming from the switch. Cut a thin piece of rubber from an eraser, and gently stroke the wire strip with it. It works!
Aug 19, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
413 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
