Question about Acer Aspire 3000 Notebook
Battery problem with the Aspire 300
I've figured out that to make my laptop work, I have to run it without the battery. If I get a new battery, will it work right or am I stuck with AC with this laptop? And should I get a factory replacement or is there something better out there?
  • 37 Answers
I had the same problem once before. I bought a new battery but it did not help. I ended up having to install all the Acer speciffic software, i.e. empowering framework, ePerformance and most importantly the ePower Management software. Once I installed all that, my batt icon showed up and started charging. Before that it wouldn't even recognize the batt. Hope this helps.
Posted on Sep 10, 2008
Laptop wont turn on without battery in
some laptop wont run with out battery in.
Apr 20, 2014 | Acer Aspire 5920-6727 Notebook
Aspire 2225g works only without battery
You need to replace the battery. A lot of laptops will work from AC adapter when the battery is out but when the battery is installed they default to battery and the AC adapter defaults to charging. When the battery is bad you get the results you describe. If for some reason it did the same thing with a new battery then the power circuit would need to be replaced, but this is not typically the case. Almost every time I have fixed someones Laptop with the problem you describe, a new battery was the solution.
Mar 17, 2014 | Acer Aspire Computers & Internet
Power goes on and off continuesly
Yeah, i think your HDD might be lifespan is nearing it end.
if you want to back up your data inside that HDD, assuming you gonna buy a new HDD soon, just give your current HDD to the seller and they will gladly extract whatever they can from it to your new HDD.
Jul 23, 2013 | Acer Aspire 5742 Notebook
I have an Acer Aspire 7741Z-5731. I've had it for
If you changed your laptop battery and charger now nothing left to change. It could be problem related to you laptop motherboard.
On your laptop battery charging section not working properly. you can check you your laptop motherboard.
Jun 16, 2012 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Battery stopped charging
Yeah It Sounds like the battery is just had its last charge they only last for about 300 charges a piece i would get a new one go for at least a six cell they will last longer...Let me know if this works for you.
Apr 20, 2009 | Acer Aspire 3690 Notebook
Acer aspire 3000 battery problem
I think due to Battery your laptop should not be slow . But as per the RAM in your laptop you need to add some more RAM with WinXP and SP3 with the type of Configuration it will be slow with or without power.
Mar 12, 2009 | Acer Aspire 3000 Notebook
Aspire 5500 power problems
Right click on the desktop, then click properties. Open the screen saver tab and you will see a box that reads power. You can adjust your power settings from there. Although it sounds to me like your battery may be wearing out and need replacing. If you're new settings don't work, try running it just on AC without the battery for a while and see if it does the same things.
Jun 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Apr 06, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
