Question about Asko Dishwashers
Asko model D3550 commences washing cycle stops after two minutes displaying code F7- Does not inlet water to machine
  • 55 Answers
SOURCE: Asko 3350 Dishwasher
The "F7" code means that the drain is blocked. To remove items from the drain: 1.Turn power to unit off. 2. Remove the "Coarse Filter" by squeezing the tabs together and lifting out. 3. Remove the "Fine Filter" and "Main Filter" by removing the screws around the filters and lifting them out. 4.Remove the small black adapter piece and check the sump area for debris. 5.Wash the filters out gently with hot, soapy water. DO NOT RUN THE UNIT WITHOUT THE FILTERS IN PLACE! 6.Replace the black adapter piece to its original position FIRST (Important!). 7.Replace the filters in reverse order of removal and turn the unit back on. The error code should reset and work normally. *In areas with hard-water, the filters should be removed every 8-12 months and submerged in a chemical solution (CLR or LimeAway) to remove mineral deposits. Hope this helps...
Posted on Sep 04, 2008
SOURCE: asko 1605 cycle stopped, pump keeps running
Same issue with mine... Tray fills and the wash cycle will not end. Sponge out the pan, re-set and your good to go for a couple of washes.
On closer look looks like a small leak in a corrigated tube and when the cycle starts a small spray of water leaks out causing the try to re-fill.
Now If I could figure out how to get in there and replace the tube I would be a happy camper.
Posted on Jan 07, 2009
  • 2605 Answers
SOURCE: Asko D3530 water inlet fault code, water valve is
It is common for these valves to "appear" to be ok, meaning they begin to allow water into the unit, but then one of the two coils or plungers inside fail, or are clogged with mineral deposit from the water or other debris.
Change the valve and you should be fine. part #1164471, you can find it at select parts depots or on-line retailers like etc.
** Hire a pro or make sure to use a good replacement clamp on the fill line to the tub when you replace the valve, as well as some plumbers puddy/tape on the inlet fitting. Those little buggers have alot of water pressure going thru them when they open and I've seen them come off or leak due to insufficient fastening/loose clamps, then your machine goes into "flood mode".**
Asko seems to be repeating their past. On the earlier DW95 series (mid 90's to around 2000ish) they had a dual valve inlet which had a single valve rework issued to repair the faulty dual valves, now it looks like they're doing it again. Go figure.
Hope that helps, let me know.
Good Luck :)
Posted on Oct 28, 2009
  • 192 Answers
SOURCE: Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Posted on Mar 26, 2010
  • 2605 Answers
SOURCE: never ending cycle
Hello Lynne, welcome to fixya.
I know what the problem is, though you may not like it. I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line. Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher.
That is just a suggestion out of courtesy however...
If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to.
The reason your dishwasher is displaying a "1" is the control has detected a heating error. It isn't the countdown time. The error code is displayed by the number "1". Here`s the most likely reason why it has detected the error...
Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry.
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Posted on Jun 14, 2010
Testimonial: "You're very thoughtful to have such a thorough reply! I will try to digest this info and proceed! Thank you"
Asko D3350 code F7
you seem rushed
the problem might not be in your senser or timer but in the pump its self
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Oct 06, 2015 | Asko Dishwashers
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
LG Washing Machine stops spinning in mid cycle
• Water supply is not adequate in
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
Apr 27, 2009 | LG WM2487H Front Load Washer
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Asko Quattro 6661 water inlet fault
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Jan 07, 2009 | Asko W6661 Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Open Questions:
Dishwashers Logo
179 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
