Question about Zebra TLP 2844-Z Thermal Label Printer
Zebra 2824 red light
Hi there, sorry to bother you, I noticed a posting for zebra 2824 going red after printing a few labels, press green then print a few more and goes red, i tried manaul calibration, checked label size being spot on but it still goes red, any other reasons, would be much appreciated
tx
darren (darren@entimex.com)
  • 4 more comments
  • wlb73 Sep 18, 2008
    I'm having the exact same problem. I haven't been able to figure it out yet and I've tried all the same things you have.
  • GISELE VAMP Sep 23, 2008
    The same problem for me. Label prints partially, then feed button gets red.
    Suggested solutions doesn't work. When pressing the feed button (printer out and on) no label is printed and the light blinks red.
    I reinstalled the driver, checked label parameters, even entered
    ECHO ^default>LPT1 in the DOS command to reinitiate the printer...
    Any other suggestions?
    Thanks
  • NHCHCenter Oct 20, 2008
    OK So what is the solution. This one does not work.
  • dosetddaram
    dosetddaram Jun 30, 2013
    hi , it has 2 reasons 1
  • dosetddaram
    1: your ribbon is not set correctly on it's possition ( it has one hole to hold by role) u have to check it first or your ribbon is set badly
  • dosetddaram
    2 : it's door sensor is error base , if u press on door and send a print red light prob was solved ur door sensor should be cleaned , ...
    New Friend:
    Problem Solver:
  • 10 Answers
Posted on Jun 30, 2013
Switch off printer at the side. hold down the green feed key, switch on whilst still holding- as soon as you see a red light let go, then as soon as you see another colour hold it down again until it goes amber. then let go. let it go green, then switch off again. then once again hold down the green feed key and switch on, only this time hold it down untill it flashes red twice then let go. it will then print out a series of label. after this, press the feed key a couple of times until the last label is blank. you may need to repeat this process. if this fails to work then it is a firmware issue and should be sent back to who you bought it from for a technical examination.
Posted on Nov 03, 2008
I have this exact same problem. Any help or suggestions greatly appreciated.
Posted on Oct 10, 2008
    Scholar:
  • 45 Answers
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Posted on Sep 20, 2008
Printing on two labels
lets start with the basics.
Do a calibration of the label to the printer : -
1/ Turn off the power
2/Press and hold the feed key
3/ Turn on power and wait for the green feed light to flash twice.
4/ Release the feed key
5/ The printer should feed and print the configuration.
Now press the feed key and the label should feed and stop at the gap.
If this does not work , then let me know via this page.or contact me at the link below
trev
thermal labels printers co uk
Mar 06, 2014 | Zebra TLP 2824 Printer
Zebra eltron LP 2824 printing too light
This could simply be old direct thermal labels. Direct thermal labels have a shelf life of about 1 year from the date of manufacture. After that time has lapsed the thermal coating on the labels begins to dissipate and this will cause labels to print light or faded. You can trouble shoot with a roll known to be fresh. You can get one free here to test Labeldomain com .
If this does not solve your problem then please check this article on 5 common print quality issues and how to correct them Fix Zebra 2824 2844 3842 print quality
Jan 28, 2014 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2824 Plus Giving Endless Labels
OK where is the print spooler on the remote client or the server. Have you check whether this is clearing and not an issue with your remote setup and not the printer does the printer work correctly attached directly to the server break the problem down in stages
Dec 07, 2012 | Zebra LP 2824 Plus Thermal Label Printer
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
Our LP 2824 Zebra printer stalls with red light when printing labels. Tried calibrating but it stalls with solid red light before printing out data
Try another roll of labels? If that doesn't help, it may have a problem with the sensor that checks the starting point of the label. These are old so it's easy and cheap to replace with a similar unit.
Oct 13, 2010 | Zebra Eltron LP 2824 Thermal Printer
Labeller not printing in black - appears to be white
possible the ribbon is on the outher way.
The darkness is to low.
Dec 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2824
the error you are getting is a label size error. a label variance of as little as 1/203th of an inch can cause this.
you need to recalibrate the printer to the media, hold feed when powering up the printer letting go once the light flashes 4 times. this will force the printer to autodetect the label size.
if you are specifying the label size in you software or driver settings, measure and double check the label size
Dec 04, 2007 | Zebra TLP 2824 Printer
Zebra TLP 2824
are you able to give me 2 print dumps? change the printer port to file and post the files content here and I will tell you if it is a config/software issue, it sounds like the software is not setting the label home position correctly(R command)
Nov 07, 2007 | Zebra TLP 2824 Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
1,161 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
