Question about Bosch Kitchen Ranges
Nht 72 - ignitor clicking - Bosch Kitchen Ranges
  • 639 Answers
Peace
ngfam1 at your service,
Sounds like a bad igniter or a clogged gas line leading to that igniter! You may have spilled something or boiled over and clogged the burner!
If you have sealed burners , the cap and burner should lift off.
And the channels in the lift off burner if they are clogged may be cleaned and remedy any spill blocking the gas passage ways.
I am not there to give hands on diagnoses.
But I can give you a good service that is nation wide!
A&E Factory service .
They answer 24/7 to make appointments!
And have a reasonable service charge of $75 around our area
Remember though, if the unit is 10 years old or more it may not be advisable to put good money into bad!
New appliances are much more efficient and pay for them selves in only a few years!
Bless You,ngfam1
Please give me a good rating in our fiya.com sight before you sign off!
Posted on Sep 03, 2008
NHT SubOne makes hum when the standby mode is activating and when playing music there are pops when the volume gets loud.
Hums are generally caused by electrolytic capacitors that have gone. You should replace any large ones in the power supply section of the unit.
May 28, 2017 | The Audio Players & Recorders
NHT sa-2 amplifier won't go into standby mode after 10 Minutes of no signal
Does the NHT sa-2 have it's own pre-amp? Because I'm wondering if the power off only works when it's own pre-amp is used? So when your receiver is connected it's shut off.
You could try something connected to it's own pre-amp (if it has one) and see if it goes off when there's no signal from that.
Jan 30, 2015 | Audio Players & Recorders
Firing order 84 madza rx7
If your tach does not work that is a symptom. Of course a timing light is most useful. If not you can coil wires (swap with known good wire) ; check ignitor,(swap trail/lead ignitor plugs at distributor) coil, check with ohm meter.
Trailing ignitors are very common failures, especially when either jump starting or being jump started when a battery is stone dead. What happens is there can be a huge power spike through the ignition system damaging the electronics in the ignitor. 90% of trailing ignitor failures happen during a jump start procedure.
At this age though, wires and coils can be suspect. My recommendation for ignition parts, Mazda Mitsubishi Cap/rotor and NGK wires and plugs. They are good enough for Mazda factory race teams and I have been using them since 72 with no ignition related failures in racing or all the street vehicles that have been maintained. Most critical is the fit of the rotor, it should be very hard to install, very tight fit. If loose the rotors have a tendency to rotate and move causing changes in timing and at worse damaging the cap and rotor.
Apr 20, 2013 | 1984 Mazda RX-7
My house never gets above 72/72 degrees and at night its around 64/66 degrees. The thermostat is at 90 degrees. It seems like the ignitors do not stay fired up long enough. What do I need to replace,...
It could be a couple of things. without knowing the model number. Could the flame sensor not sensing the flame and cycling on and off or it may be an exhaust fan switch causing the flame to cycle on and off. watching the flame while its running might give an idea whats happening during the heat cycle.
Dec 19, 2010 | Gibson Heating & Cooling
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
Tappan gas range model 72-3981-00/07. Upper oven does not ignite even though the igniter comes on and glows yellow.
The ignitor is weak and must be replaced. When you get the new ignitor turn off the gas supply and the power to replace the ignitor.
Remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Jan 10, 2010 | Tappan Ovens
NHT SA-3
Appreciate the direct "Ask Me". With reference to your post here;
Voltage checks are done with the power on whereas resistance/continuity check are performed with the power off and preferably the component out of circuit. The VOM would do.
You posted that the fuses have not blown and therefore you are assuming that the output transistors are not defective. Pls confirm this by performing a check on the base to collector to emitter of the output transistors. This page would illustrate how to check a transistor using a VOM. The output transistor once removed from the circuit (pls mark which goes to where), laying flat with the pins/feet pointing towards you would be base, collector and emitter. Although the real outputs if 2SA1302/2SC3281 would be larger.
Most NHT sub amps are standard design amplifiers. To my knowledge, NHT amps (but not all) uses a unique design to supply power to the output transistors. The fuses does not tie directly to the output transistors from the +/- of the power supply. Instead the fuse goes to several power MOSFETS (IRF640) that regulate/control/monitor the current/voltage supplied to the output transistors. If any of the IRF640 is blown, the output would have no voltage even if the fuses are good.
To be more specific and to confirm the above, would appreciate if you could post/share the schematic diagram.
May I also inform you that there are posts made by other members of the community (our co-experts, I am aware that you have provided solutions yourself in some other posts) that would be of additional help. ginko has posted the method/manner by which you could test the transistors and other components, while bunnydawg addressed the fuse not blowing. welcomejee has posted with an amp schematics of an NHT Subtwoi.There were however and I would expect more posts that are too general/generic to be of any real use to you. I would leave it to your discretion to filter through the flood of information.
As a site policy, once you rejected a solution or give it a "Thanks for Trying", that particular post/expert would no longer be viewable. For your benefit, may I suggest that you copy and paste the "workable solutions" to a document that you would have a record of previous or no longer viewable postings.
Jan 04, 2009 | Audio Players & Recorders
Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Nov 19, 2008 | Tappan TGF320 Gas Kitchen Range
Technics sax-710 receiver Nht sb-1 speaker developed a buzzing sound when playing, Kids may have over drove speakers(not sure) Replaced with nht supezeros now both speakers sound very staticy like off...
The speakers have buzzing sound because of damaged cones.
Over driving speakers, especially with heavy low frequencies, can tear the voice coil away from the cone.
Once damaged, only replacement will help
Apr 24, 2008 | Audio Players & Recorders
Zire 72 and Outlook 2003 - I think I've tried it all! Doesn't work....
you don't need pocketmirror for zire 72 because palm desktop have outlook conduits to handle outlook synching. inorder for you to sync using outlook you must have the outlook conduits installed which seems you have it already installed. you have to disable some older conduits inorder to avoid conflicts with the conduits. to do these follow these steps: 1. right click on the hotsync manager icon on your system tray 2. click on Custom... 3. select Date Book (Outlook) 4. click on Change... 5. select Do Nothing and set it to default 6. click Ok 7. repeats steps 3-6 for Address Book (Outlook), To Do List (Outlook) and Memo Pad (Outlook)
Sep 07, 2005 | Palm Zire 72 Handheld
Kitchen Ranges Logo
302 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
