Question about Refrigerators
Hotpoint no frost ctx21ga refrigerator leaking water
I have an older model Hotpoint refrigerator. Its self defrosting with an ice-maker thats not hooked up. Recently started making loud "clunking" sounds as it cycled and now there are pools of water underneath fridge all over the floor. Some days worse than others. Any suggestions?
  • bendar Mar 24, 2009
    Water forms in bottom of fridge under veggie trays. Fills up and leaks on the floor when the door is opened.
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
  • 1462 Answers
SOURCE: Hotpoint Ultima Fridge/Freezer keeps leaking underneath
yes this is probably the source of the problem - the defrost water doesn't flow down the drain.
melt the blockage with hot water till you get free flow down the drain - takes a bit of patience
tresilla
Posted on Aug 29, 2008
SOURCE: JCD2389DES Water Leak Problem
Once I saw that the drain tube went up over the coil before draining into the evaporator pan I decided to buy a small piece of flexible plastic tubing and re-route the tube so the water could freely flow down hill. It's been over two months with no additional problems. I can assume that since the water drains freely it doesn't stay trapped in the elbow freeze and the cause the collector tray to ultimately overflow.
Posted on Nov 24, 2008
aborcass
  • 2651 Answers
SOURCE: water leaking from freezer /
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Jan 25, 2009
Sea Breeze
  • 4638 Answers
SOURCE: Frost is forming in the freezer Hotpoint ctx21ga
I am looking up your model now, it is for sure in the defrost circuit that is causing this. Yes, from what I can find your model has a defrost timer. But have not located where it is, most times 2 places, behind kick plate near floor or inside fresh food cabinet inside the panel where the temperature control is located. When you locate it slowly turn clockwise until refrigerator stops running. At this point it should be in defrost. If timer does not work it will need replaced. I'm still doing some searches on your model so please understand this is not a solid yes, that this is your problem, but we will find it. Let me know what you find, Thanks, Sea Breeze
Posted on Apr 20, 2009
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
I have a Kenmore Model 60192000, freezer on top and no ice maker. Have a leak on left side over top shelf. It is coming from apart in the refrigerator above the shelf, has kind of a square neck. I do I...
Is it a leak or a drip? A leak means you have continuous running water and a drip is more inconsistant.
I would suspect that you have a drip, that is caused by your cooling tube having frost or ice buildup in it, which is quite common for some units. The fix that seems to work the best is to defrost your unit, making sure the cooling tube is completely free of ice and frost by blowing hot air from a hair dryer down it. Then cutting a piece of bare electrical (solid core) wire that will fit down the tube but not extend past the opening. Then you form a hook and put it around your defrost heater.
That way the heat from the defrost heater will be transferred down the wire and keep the tube free of ice and frost.
Jul 28, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Ice on the food
why did you stop the ice maker? was it not working properly? was it over flowing or leaking? do you have a sheet of ice forming in the ice maker tray? if your ice maker was leaking then your water valve is not shutting off completely and could be leaking down on the food. if this is the case - you need to shut the water line off coming into the refrigerator and replace your water valve.
if it is frost that is forming on your food instead of ice then you should check to see if the refrigerator is defrosting properly. if the refrigerator is not defrosting properly you would also first notice that the refrigerator is not cold enough and then later that the food in the freezer eventually thawing.
May 28, 2010 | GE GSS20IEP Side by Side Refrigerator
I have a water leak that goes into control box & then leaks out forming a small icycle It is an IM-6 Ice Maker
http://sites.google.com/site/sublimeappliancerepair/refrigerator-problem/defrost-info/ice-maker-quit-making-ice-im-secrets
Here is a link to common ice maker problems. Chances are you have a pin hole in the water line. It may also be a leaky water valve which is on that link. also check for a broken ice mold. Best of luck.
Sep 23, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
I have a CSX22GRB Hotpoint fridge and 1)the ice maker is not making ice 2)there is ice building up in the back of the freezer 3) the main fridge is not cooling
Hi, Id there ice or a frosty build up on the rear wall?
If it is ice, the drain is plugged. If it is frost, there is a self defrosting problem.
Please let me know so that I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Apr 20, 2009 | Refrigerators
The freezer has ice build up on vents
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
also click the links below for more help
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
No water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Jun 26, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Refrigerators Logo
    524 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
