Question about Zanussi Dryers
Belt broke. zanussi tc482w belt no 125828800 1975h cant get one can u help
For a new belt for your tc482w tumble dryer contact service force spare parts phone number is 08444 776260.
Posted on Apr 01, 2009
Hi we are trying to fit a drive belt, but cant get the belt on its to tight, cant find an adjustment lever or anything can you help?
hi providing you have the right belt. run the belt over the pulley until its tight (it will only go half way round and feel impossible to get on but just run it on like you would cycle chain it takes some effort but once the belt starts to stretch you will find it will go on. just brute force will do it. good luck
Nov 15, 2010 | Zanussi FS1255S Front Load Washer
How do you change the belt on a zanussi nexus fl 1082.iv got the top off and tryed to slip my hands down the back of machine to attach the belt to the motor and wheel,but just cant get the last bit on,and...
With the help of someone, tilt the washer forwards towards you, this will give you more room to get your hands inside to fit the belt, it is awkard, but can be done, I have done it this thay on many occasions, otherwise, it entails removing the rear half of the cabinet, not an easy job!!!!!¬.
Good luck.
Oct 12, 2010 | Zanussi FLA1101W Front Load Washer
Hi, I have a Zanussi TC482W which is spinning, but not heating up
Either the main heater has burnt out or the thermostat found inside drum housing above door.Also the water tank inside the machine could be full there is normally a small rubber cap with a wire clip on it at rear bottom of machine take this off and drain water onto a towel and gently tip back machine to get all out.The other fault could be the timer.
Hope this helps.
Feb 07, 2010 | Dryers
Wiring Details
if you have just two wire on thermostat then it is
immaterial where you connect on thermostat.
ONLY IF HAVE TWO WIRE THERMOSTAT.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Changed belt on zanussi tc 482 w
heater in Zanussi tc7103s not working . stats and element ok. cant locate reset button
Jan 08, 2009 | Zanussi TC7114W Electric Dryer
Dryer squeaks when I use it
Hi, I had a squeaky Zanussi TC482W. Had it apart (easy to do) by taking the back off. Cleaned out fluff from around the drum and greased the rear bearing. Reduced the amount of squeak but still there. Took it apart again and almost by accident discovered that the bearing that the shaft at the rear of the drum sits in is actually in two parts. The actual bearing is shaped like the olive you get in plumbing compression joints and should be free to swivvle in the housing to allow some flexibility in drum rotation. A squirt of WD40 and some gentle wiggling with a piece of dowel soon had it free and its now flexible enough to take up the slight movement of the drum about its axis . Problem solved.
Aug 13, 2008 | Dryers
Zanussi zwf14581w front load washer
Are there clothes locked inside machine or water visible inside machine? Either machine has not drained eg.blocked drain hose or pump, or door lock broke .please reply.
Jun 02, 2008 | Zanussi Washing Machines
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Fixing a belt to a Zanussi Condenser Dryer
when you say "only one pulley...", are you counting the motor as one? there should also be a tensioner pulley...look for it somewhere near the motor.
Oct 31, 2007 | Amana ALW480DA Top Load Washer
Changing drive belt
ensure that the tensioner pulley wheel is also part of the belt loop and that it is properly sprung to take up slack. sometimes, this pulley looks good mounted in reverse, giving no tension to belt. try it the other way, against the spring force.
Sep 23, 2007 | Dryers
Dryers Logo
354 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
