I have a Norcent LCD TV which started getting white hyroglipics on the screen, then occasionally would break into close captioning and now i gets green pixilations on alot of the screen especially when the background is dark. It doesn't happen 24/7, but alot. Is it worth trying to get repaired?
  • dianetice Sep 03, 2008
    I was not given an answer as to what is wrong with it and how much it might cost to get repaired. The TV is over a year old.
  • 6,487 Answers
Yes, its still worth fixing this unit, if you want you can check this site they offer service for this type of repair , they will be able to fix this and a reasonable price http://fixmymonitor.com/
Hope that helps..........
Posted on Sep 14, 2008
    President:
  • 1,263 Answers
Go to your set-up menu and select the convergance option, try adjusting it. then go into you picture options and adjust you sharpness and your contrast. if this doesn't take care of it it's and internal problem on the main board. close caption is on the audio signal and has nothing to do with so if it is bleeding over on your screen with out it being selected it means that the interface circuit is bad seeing that it's still under warrenty i would take it back, because repairing it would cost quite a bit. good luck
Posted on Sep 03, 2008
    Master:
  • 521 Answers
Its the problem in your convergence --STK ic---- of the main board.get it repaired quickly or it will cost u very heavy.as the problem you are facing will increase further with heavy pixilations been seen and also for 24/7. at present its just the starting slowly ----slowly it will start increasing.the cost at present will be under the service charge of the technician.
pls do rate the solution
thanks.
regards.
fixya expert team
  • 1,879 Answers
Tried turning off the closed captioning feature ?
  • 2,326 Answers
How old is your LCD?
If under a year old, still under manufacturers warranty. The cost for the repair if exceeds more 1/3 of the price of the LCD, it might not be worth it to get it repair.
  • Jaime Hernandez Sep 03, 2008
    The pixels could be cause by a defective main board or a power supply not providing enough power to the main board and the rest of the circuitry or a weak signal source.
    The estimate for a repair could anywhere from $300.00 to $400.00 maybe more depending on parts availability.
    Are you using cable TV or satellite TV?
Can't get closed captioning to go away,,, can't find it on the menue does anyone know how
Check whether there is a "CC" button on the remote control. If you are using a universal remote control, it might not have this button. As there is no selection for closed caption in the TV menu options, its original remote control will have this CC button. If you are the original remote, press this button once.
Jun 08, 2012 | Norcent Technologies2703 27" TV
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2,3..now u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Dec 10, 2010 | Broksonic TV
How to reset closed captioning on a sanyo flat screen. Followed all directions 3 times and no writing on the screen. Grandpa needs it to watch his tv.
U have CC button on ur remote?Push that button on like CC1,2,3 one of these will get u captioning,but the show must have captionning in it programming it have CC and a square before show started it indicated it have captioning.
Mar 18, 2010 | Sanyo DP32746 32 in. LCD Television
Black square on screen of 19 inch TV
Check your closed-caption settings and be sure they are turned off. If captioning is set for text mode you can have this trouble. The TV blanks out a part of the screen for the text it never gets to display. Once captioning is shut off (or set for normal caption mode if you want to use it) the black box will be gone.
Feb 04, 2009 | Konka K1938U 19" TV
White Westinghouse 32 in Issue
Turn off the closed caption portion in the menu . The text 1-2-3 or 4 is on blanking out the center of your screen . The closed caption button could be on your remote and is being accidently pushed . Good luck
Mar 03, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
