Samsung SCM-8300 CD Player
When putting CDs in, the system reads where the CD is at then deletes them from the display and read no CDs while up to 5 CDs are in the carriage. Can you solve the problem without getting a new chip or software. Thanks, Ron
Hey ya i had the same prob but i opened it up and took a cotten q tip and cleaned of the eye
if this does not work u may have to take it to a tech
remember clean it well
Posted on Nov 19, 2008
I have a Samsung SCM-7450 Hi-Fi System. The CD player has stopped recognizing that there are CDs ready to play. Any suggestions?
There is nothing you can do and I doubt leaving the CDs in the unit would have made any difference with the problem you have now.
The CD player is an integrated unit with tape player, turntable etc so there are presumably no connections on the back of the unit that would allow you to connect a new CD player and run it through the unit. However, if it does have compatible connections then that is what I would do.
Dec 26, 2015 | Audio Players & Recorders
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Doesn't read the cd. says
If any cd player does not play, three things, it either the wrong format, dirty cd or faulty cd player. If your cd player play others cd, it mean others are the wrong format. for example older cd player is not compatible to play some of the cd formatted from the computer. if the cd player does not play anything that mean the cd player is faulty.
Aug 27, 2009 | Sony Audio Players & Recorders
I hve a gemini cd 200 and the left deck stopped reading cd's. when i put in a disk the lcd reads no disk. What cuold be the problem.
Just like with any CD player, the optics have lifetimes. Either the optics are dirty and can not read the disk or they have failed. These units use KSS-213 optics assemblies from Sony, if I remember correctly. These can be purchased for around $25. Any one with audio repair experience should be able to replace them for you.
Dan
Jul 31, 2009 | Nu Mark Numark CD-Mix-2 Dual CD...
Panasonic home theater sound system SC-HT720 won't read or play dvds or cds
mine does the same.the display flashes "prog" and --:-- on cd's,dvd's and even the cleaning disk it almost sounds like it isn't getting enough power to spin the disk.
Jun 23, 2008 | Panasonic Home Theater System System
New DVR-112D can't read misic cds or cd roms.
there are several options you can do as follows:
1. go to support.dell.com and download from the website any firmware updates available for your player.
2. Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
3. try to update your bios which you can also download from support.dell.com under downloads and drivers. just enter your service tag
Jun 15, 2008 | Computers & Internet
Disc reading
hi there
long reading time for cds or dvds only means that there might be dust or residues hindering your cd lens to accurately read the data of the cd/dvd. what you can do is try to clean the lens with a cd cleaner.always check the cd/dvd that you insert are clean and fre of dust . if this still wont work and the player still have the long time to read the cd/dvds, my advise is to bring this to a service center and have this checked out.
hope this helps.
Feb 05, 2008 | Samsung HTQ45 System
CD player will not play CDs
1.Check whether your cd s are good and readable
2.then the problem with the cd player laser beam reading assembly and its associating blocks
3. i guess your cd player laser beam lens is too weak or dead.
4. There is possible to change the lens system with a new one
5.Contact service centre for further rectification
Dec 19, 2007 | Audio Players & Recorders
Won't play a cd
We have the same problem and are searching all over the web for a solution but no luck. If we find a solution we will come back and post what we found. :)
Oct 15, 2007 | Emerson MS3111M Shelf System
Error 2 on Display
Mabye. I would suggest either opening the unit up and cleaning thr "laser" (optical pickup) with a q-tip. Or try using one of those cleaning cds that have the little cleaner fabric on the inderside... if that doesent work something is most like wrong with the cd machanism wether its not spinning the cd or just not reading it due to a defective laser.. ampman!
Sep 05, 2007 | Sanyo ECD-T1550 CD Player
540 people viewed this question
 Grubhead
Grubhead
